I doubt there would be much to review about it. Its a reinforcement bar to prevent subframe tear out. Its the swaybar that does all the handling aspect of it. My question is at the price should we go for it?
Yeah the only ppl will benefit from it are the ep3 si guys from the states running bigger sways, The price wont vary much I put a order in already and apparently it has arrived so ill try and get it installed soonish. If you can find it cheaper than 200 it will be good.
arrr nice I went with the normal silver, I was planning on black but it will look wired with a orange sway since lower control arms and rear sub frame isnt black.
Do u guys know If the function7 subframe will fit if I have a whiteline sway bar on the ep3?
Lol I just used Sikaflex (3m window weld alternative) to fill my transmission mount, and my god that stuff is messy as hell to use, once it gets on something you'll have a hard as hell time getting it off. It dried pretty solid, but I think i left some air pockets on some sides since it was pretty hard to tell what I was doing.
Shifts feel more smoother now, especially shifting at high rpm; vibrations isn't much difference since i got a Hasport side mount. Yes it's pretty ghetto, but its doing it's job lol and if it fails in the long run i'd probs upgrade to Hasport anyway.
