I'm actually paranoid about getting dyno runs. Seen too many "dyno gone wrong" vids on YouTube.
If i wanna replace door speakers, which size/model should i look at?
current speakers are so crap....
I must admit, I thought 140kw was high given the mods. Having said that, if that Mainline (Dynolog) Dyno is anything like the one that I had my car run on, I'm pretty sure that you can't fudge the temps at all. The Mainline (Dynolog) that I made 122.4kw on (stock) had its own weather station that measured all that stuff and applied its own corrections, unlike a Dyno Dynamics unit, which I understand relies on the operator to get the input right? I could be wrong, but that's my understanding of it.
Out of interest, what gear was that run done in? We did all of mine in 4th and it just clipped the speed limiter each time after making peak power at around 8000rpm, judging by the speed that it made peak power at, it must have been 3rd gear? Maybe that has the potential to skew figures too? I don't know enough about Dyno witchcraft to comment.
Either way, Dynos are a fantastic tuning tool, nothing more, the only 'real' way to find out home many horses you have is via an engine dyno, or 1/4 mile top speeds. I love a good dyno day, and if nothing else, I love spending the day watching hot cars get put through their paces. Loving the build so far RPS, that thing looks tough as nails on the rollers.
Does it sound like this?
http://www.youtube.com/watch?v=xasL7...eature=related
If you've greased up your steering rack plenty, then I would check your swaybar endlinks/droplinks, they may worn and do make a creaking sound similar to the steering rack problem, especially going over bumps. You'll have to take the wheel off and visually inspect them, and try moving the swaybar to see if there's any play. If there is, then you may need new endlinks.
