I'll do some more research and see what there is that I can find out. Worse comes to worse, I'll replace the guide seals and work from there.
I'm gonna send it to a shop while I'm up north qld. Get him to have a look over it all and give it a good inspection. Pick up anything that needs repairs and sort out the smoking.
I am still tempted to rebuild the engine though, mainly for reliability and to remove any gremlins that the horrid previous owners left.
And abused for all it's life.
That's what has been happening. It's a never ending chain reaction. Once you're done you pretty much have a new car again.
I don't know how someone can just treat something so awfully, when it has cost so much to purchase. It's like "oh yeah, it's only 10g, it's like pocket money".
Because I can't exactly say a type r is a cheap car.... Haha
Something I believe a lot of people need to come to terms with is that cars are machines, machines are comprised of parts, parts always reach a breaking point.
In short, machines break and that is just a characteristic you need to accept. It's not breaking because you have bad luck, and it probably is not because the previous owner forgot to do a few oil changes.. it's an old car with old parts.
Even if you rebuild the whole engine that does not by any means guarantee that nothing will break.
It's part of owning a car, things break, you fix them when they do.
I understand that things break. But my 98 d series had absolute no issues at all. No smoke, no knocking. Ran perfect.
Compared to the 2000 type r engine, which may I add is a far more expensive item, has had nothing but issues.
With proper maintenance and care, a machine will last a life time. Parts will give out over time, but the issue I have had is that the previous owners haven't cared to change them as they have broken. Just ignored it with the mentality of, it's not worth fixing, which is why we end up in this situation.
A 1970 Holden v8 built by Australia, has outlasted my japenese built 2000 4 cylinder. Which, by all means, should definitely be the other way around.
Just because a B18CR is more expensive than a D series doesn't make it more reliable. You're forgetting that it's much more highly strained than a low compression economy engine.
Also forgetting to factor in that the B18CR probably gets driven a lot harder (by you and the previous owner) than the economy based D series.
As I already told you, B series are notorious for worn valve guides with age. It is not surprising that it's smoking with age.
Take it from a guy who has actually rebuilt his B18 twice (so you know I'm not some forum troll spouting shit), rebuilding does not change the fact that regardless of how often you change the oil etc stuff is going to break. If you bolt on a turbo to the engine it will break things even more often.
If you want to rebuild, go ahead, it's a fun thing to do. If you want a turbo, go ahead. But just don't expect the problems to come to a halt because of it.
On a side note I have two questions simply out of curiousity:
1 - Why did you buy the engine if you know it's been very poorly maintained?
2 - What parts were "left broken" by the previous owner of the engine?
9000rpm cold shifts
nuff said
