wats d main diff between greddy n peak?
wouldnt it just matter on the motor tho?
apart from a faster spool depending on d turbo
im not getting a greddy kit anyways im piecing together my own
that question was for my curiosity lol. HIJACK
anyone know much about these manifolds???
http://www.justjap.com/store/product...roductid=16646
anything helps...
looks like a standard cat iron one. doesn't look too bad, jsut be carful it fits a/c & p/s if you still want those thing
i had one of those, it cracked after about a year.
400psi
run 500psi den start braggin
i've only seen cast iron crack where there are fractures in the cast.
A good cast will almost never crack unless it is heated really hot and hit water or something semi cold
am i able to run a stock turbo manifold say off a GTiR or a Silvia so on...???
