grille is already painted gloss black, but not sure what i want to do yet. keep it gloss black, keep it flat black, or color match it.
also, not sure if i want to put A emblem on there instead of H, or just cut out middle bar.
jdp type s lip rep
http://i179.photobucket.com/albums/w...pseaef7e63.jpg
http://i179.photobucket.com/albums/w...psb002637d.jpg
http://i179.photobucket.com/albums/w...psaa8e5a8e.jpg
current ride height and new rear tire size
http://i179.photobucket.com/albums/w...psa388b5a3.jpg
http://i179.photobucket.com/albums/w...ps3321f9f3.jpg
need more mods in the ass department
http://i179.photobucket.com/albums/w...psde3090af.jpg
http://i179.photobucket.com/albums/w...ps8f4966c0.jpg
front fitment is the only issue:
http://i179.photobucket.com/albums/w...pseedb0e0e.jpg
http://i179.photobucket.com/albums/w...psadb534f6.jpg
http://i179.photobucket.com/albums/w...ps5d71f4e7.jpg
http://i179.photobucket.com/albums/w...psa26a13fc.jpg
http://i179.photobucket.com/albums/w...ps7c2a4f74.jpg
camberrrr
http://i179.photobucket.com/albums/w...psbe3661a7.jpg
next to the neighbor's 8th gen accord
http://i179.photobucket.com/albums/w...psca4fd2aa.jpg
Your neighbor prob ask him self why he bought an accord each time he sees your car
The Accord is bigger than I thought :o
I WANT THAT LIP O M F G.
lol you would want the OEM lip. here's my review for the rep lip for those who are interested.
pro: cheap, more aggressive than oem lip.
con: its polyurthane so its hard to paint and tough to install. your shop must be really good, luckily mine was. they sand it down, fill the sides and edges with rubber fillings to make it smooth, then sand and paint, the more sanding, install it, final paint and polish with chip protection selant. also applied some sort of flex coating on there since it is a poly material, so even if it flex the paint should hold up.
fitment: sides are okay, the only problem was the front. we have brackets holding down the bottom pulling it inward while double sided tape does the job up top. not sure if that'd hold or not
if you just look at it you probably think the fitment is okay, but if you look closely around the front you can see that there's a TINY TINY .5mm gap or something in a small part or 2, which you really have to look for it (as seen in the pictures i took)
seems like people with the rep type s lip has the same problem.
if you have some money to spend, get the oem one, or the jdp cf one.
but for a brokeass college kid, this will do for now
The acoord has.proper leg room at the back
Lol omg it all makes sense. Im a fckin idiot
The kit looks a little different from the OEM. Its much thicker on the front.
^yup, that is because my lip is replica :( no money for factory lip!
and although the accord is parked closer, it is a tad bit bigger than my euro accord lol
and who needs leg room in the back, SCREW THE PASSENGERS!
