I dont use the mounts. Mine fine. I got mine for WAY less than $1400USD by using a dealer here.
Wooo hoo ! Just ordered tein ss for my euro and now just waiting for them to arrive. Are they hard to install or should i get it done professionally?
Me too. Thats the ebayer I got my ingalls from. Hes good.
its not a bad time to buy things from the US but the shipping will still slam you pretty hard
those ingalls i gotta admit are pretty good value
What settings have you guys got on your Tein SS.
I have 10 at the fronts. Thats 6 clicks counter-clockwise from the max 16 setting.
Im not sure about the rears. Ill probably try 6 for the rears. Thats 10 clicks counter.
Any suggestions?
I've got mine set on setting 10 front and back.
Bumpy roads in my area
Front 7
Rear 9
Thats the number of clicks back from the max of 16 at the full clockwise yes?
I went the full range then started at the midway point which is 8.
(damn forgotten now!...anti-clockwise is fully hard and clockwise is fully soft?, haven't touched them for 6 mths)
Setting of 8 IMHO is pretty equal to stock.
So in my case I've gone 1 click softer on the front and 1 click harder on the rear than stock.
This seems to work well over the bumpy roads in my area being a bit more forgiving in the front.
Full clockwise is hard. Full anti-clockwise is damper damage. You can only use the first 15 clicks from the hardest setting.
I see.Then the issue when discussing this is always.
Is fully clockwise fully hard setting 16 ( as i believe)
Or is fully soft, turned anticlockwise 15 clicks setting 16 ?
