Originally Posted by aaronng
When you improve breathing, what you are doing is addressing the issues of the stock breathing characteristics. As you know, at low RPM, the intake is not working at maximum capacity. So even if you changed to an SRI or CAI, they would not be working at maximum capacity and perform either the same or worse than the stock intake (which was probably designed to operate at peak efficiency at low to medium RPM). At high RPM, you start to reach the limitations of the stock intake and the additional maximum flowrate capacity of SRI and CAI start to show their benefits. That's why gains are observed at high RPM and not at low RPM.
