Originally Posted by
Chris_F
			Replacing the stock exhaust with a dual outlet exhaust has minimal gains on a stock standard car with no ecu tuning. Maybe a few hp if you're lucky.
But your car is far from standard and, with the reflashed ECU, I have a feeling the stock exhaust might be holding you back a little (hard to know without dyno testing). If you want to maximise your gains, single outlet  2.5" to 3" exhausts are proven to work well with modified k series engines. A good exhaust shop will be able to make you a 2.5" single outlet exhaust, 1 resonator (good brand like magnaflow), 1 muffler (good brand like magnaflow) and mandrel bent stainless steel piping for about $1k.
But if you want to keep the dual outlet look of the exhaust you'll be looking at a few hundred more if you go custom. There's also plenty of aftermarket options from Japan and the US. But with the Aussie dollar the way it is at the moment though your going to be paying more than usual.
I'm keen to see a new dyno for your car!
