Haha,Yeah :p
Oh great...
Is anyone here with a DC2or DC4 had any problems? (other than ginganggooly)
I'm getting some creaking sounds from the back, and I'm getting real suspicious.
Crawl underneath and check.
the swaybar makes creaking noises more often than not , because of lack of lubricant on the bushes. You can relube them and the noise generally SHOULD go away.
yup the "heavy duty mounts" on the EG and DC are less likely to have this problem - still not a good design. My last kit had worked itself loose when i pulled it off.
what reinforcement plates do you refer to blitz ?
Mine makes a firm noise (like a bolt slip) everytime I turn.
I checked mine under the car but the reinforcing plate covers the joint, so it's still a mystery until I totally remove the bar and reinforcing plate. I havn't retightened the joints in a long time either.Quote:
Originally Posted by bennjamin
please get your car checked out either at a mates or a mech and see if your kit has a problem
IMO take the kit off and ask whiteline for a refund as the risk is too great....
So, Which Swaybar Is Good For An Ek Now?
either a DC2R or EK9 rear swaybar
EK4 OR ek9 swaybar endlinks.
+ ASR Brace
IMHO opinion, sway bars r the same, just m ake sure u get the correct reinforcement which atm is ASR brace
