theres one in perth for 15k blue one in scarborough gumtree,
The front and rear bars appear to have been resprayed, as the fog light section is sprayed blue and the rear lower diffuser bit also appears to be sprayed blue, could be nothing but just thought I'd let you know
S2000 sold finally. Sad day :(
^ Good job mate. What ya getting now?
ap2-CR :)
AP2 CR? Is this a lhd import race car or do you live in US?
Sorry wrong forum!
What about these two ?
http://www.gumtree.com.au/s-ad/yagoo...00-/1026398558
http://www.gumtree.com.au/s-ad/green...del/1026083785
anyone check it out yet ?
Top one looks dodgy with no grill, painted rear diffuser and questionable bonnet line. Front and rear collisions?
Lower example looks like fenders are rolled, stanced suspension is for looks and obviously metal has been cut to make the ap2 rear lights fit.
^ +1 first one definitely looks dodgey - That radiator is definitely not stock, not sure if its just the pics but the rocker cover looks faded as, the painted rear diffuser also raises alarms, the edges of the bonnet looks chipped/rusted? bonnet definitely doesn't line up & missing grill/tow hook cover.
Probably a bad front end repair job and cbf'd to replace the small bits, i'd personally stay away from that one.
I'm glad you didn't drop the price on carsales by too much. So many ppl are in a rush to sell and drop it below what it's really worth. Kills the entire market. Patience is all it is.
Re:370 have you driven one? I was in the same boat a few months back when I wanted to sell my honda for the 370 until I drove one. Each to their own but I thought it needed more power. The engine only really pulls you when you're in the passenger seat. And the s2000 still wins in the handling department. It is newer though and does look awesome but i didn't find it to be a better car than my s2000 (for 10k or so more). in the end i didn't bother buying one.
in regards to the 370
the engine pull is so linear that it doesn't feel fast. it's fast but boring.
http://www.carsales.com.au/private/d...S2000-15436560
Anyone had a look at this??
in picture 6 the pasenger footwell pocket is missing?
what looks like a dent on rear qtr panel above the rear right wheel.
Ah yep, dent or could be the reflection/lights
Monte Carlo blue s2000 that has rego ATA 652 belongs to me but some scammer is using the shots the owner before me used to sell the car...... So annoying
Ah I see
Tried calling the number twice but it goes to voice mail lmzo
If monarofans s2000s interior had been upgraded does that include swapping of the cluster..
Or is it just dash, door cards, carpet??
Anyone that has inspected it, pm me!
Cheers
I have, the A**holes have listed on trading post ebay and gumtree. They nvr return calls so I don't know what their scam is
Yeah I am changing plate, just using up the WA rego a little longer seeing I won't get much back and it's a lot cheaper than NSW rego
hahaha, are you still running the stock cd stacker?
http://www.carsales.com.au/private/d...SSE-AD-2088029
Anyone inspected this s in nsw??
Question.. Inspected a s2k park brake light was on(!)< asked the owner and he reckons it's because the brake pads need changing??
I personally reckon it's bullshit.. But maybe I'm wrong..
That was the case for my previous BMWs, don't know if applies to S2K though... Google?
Brake fluid reservoir is low or float is stuck
I don't think s2ks have that 'thing' like BMW but I could be wrong il google and research it!
Still don't understand how the park brake light is on if fluid is low..
It's a combo light, handbrake and brake system indicator.
It's not a brake pad indicator if that's what you're referring to.
I understand that..
What l mean is when I put the hand brake down the light was still on I asked the owner why and he said its because the pads are worn and when you change the pads then the light will go off when handbrake is down??
I guess the owner could be correct in that the pads are worn and there has been more fluid drawn from the reservoir to compensate for pad thickness - and the light comes on to show the reservoir is low.
Having said that if the car is being maintained on a regular basis the reservoir should be checked and topped up if necessary (or pads replaced).
Putting new pads in would push the reservoir level up and correct the light - but if pads are being changed you'd generally flush the lines so it's a moot point I guess.
I'm not familiar with b series engines but I need to top up my s2k oil every 5 months or so and I use it as a daily. It's not excessive though, have a golf gti and that tends to consume a lot more.
anyone check this one out yet ?
http://www.carsales.com.au/private/d.../?Cr=1&sdmvc=1
low km but seem likes the front bumper has been resprayed
Brake light on
means low brake fluid mate...
Maybe a leaky brake line
if pads are low the fluid would be low too, try top up fluid and see if that does it. or maybe the switch damaged.
unlikely i leaky brake line but it is possible! more likely a BMC.
2000 white ap1 with red leather only 74,000km for $25,000 bargain if all checks out Victoria on carsales
Seen that, front bar has been color coded??
Yeah noticed that and no front badge but who knows might be clean. I just thought to list anyway
Yeah and front badge too.
Me personally for a 2000 wouldnt pay $25k you can pick up a 02+ for 25-27k+
The cluster pins are gone, so there's a possibility that the cluster has been tampered with.
get the log books
It's not even on carsales anymore lol!
Dodgy and removed? Couldn't have sold that quickly
Hey guys.
I got an 02 s2k red, stock, just over 30,000km on clock. I might be putting up for sale shortly. Going to use it for a wedding shoot toward end october, but after that should let it go.
Just a heads up incase you wanna wait! Ill list it closer to the date tho.
Bit of history; full service by honda. Second owner, first owner used car for shows, and resprayed bonnet and FL fender to remove imperfections. bought with 20,000km.
As you could guess, ive had no problems with the car. Last service was a major cos it hadnt been done in a little while, and next service is due and will be done this month.
Pm if you want info, but car isnt up for sale yet, and ill be looking for premium $.
In the meantime: 90% of white s2ks i see are not original so be weiry
how much will it sell for with 30k kms in melbourne?
i notice the ones in perth are a lil cheaper then over east....
02 with those kms in Melbourne I'd say owner can ask for nearly 30k. Most ppl on here are stingy though and will prob disagree
Bb 08 ap2 back up on carsales on another note
Hey im with u on that, im pretty stingy too should of seen me haggling for mine once i finally found it! They didnt budge not a dollar hahaha. Still worth it! 30k yeh i think thats the ball park being the newest ap1s available! Ap2s are pretty hot tho
Anyone know anything about the supercharged s2k in perth?
Hi everyone!
Has anyone looked at this one? http://www.carsales.com.au/private/d...?Cr=16&sdmvc=1
I have read the whole thread but can't find anything about it.
Thanks.
Has anyone had a chance to check this one out? Looks pretty clean
^ Its been up for awhile and being GPW the real keepers are usually sold in hours/days, a fellow member on here inspected it maybe a month back and said it was making some strange sounds?
Those seats are gross. What's with the front bar resprays on nearly all the early model s'
And you'd be stupid to buy that white s in nsw over this just to have a white one.
http://www.carsales.com.au/private/d...S2000-15562617
Subject to overall condition of course
But its silver!
I was actually keen on this one a month ago but there was no contact number & realistically speaking it would be too much of a gamble to out 20ish grand on it and just assume the sound was the front sussy.
More than likely the sound is caused by the sussy but until that can be verified by someone who knows what they are doing or unless he fixes it prior to sale it looks like it's gonna be hard to find a genuine buyer or else it would've definitely sold by now.
I saw this one also a few weeks back and i don't mean to be rude but this thing was in pretty shit condition (only saying that because the S is such a nice car and i have absolutely no clue why people wouldn't take care of this beautiful thing even though they own it????) i made a post a few pages back with more details about it if anyone whos interested in it wants to know, he was also EXTREMELY negotiable but even then i still wouldn't buy it lol :cool:
