hey guys
acura indicators should fit on honda right?
i found clear indicators but couple of mates are telling me that the globe fittings are different...is this the case?.. i assumed that they would fit with out a problem..
cheers
hey guys
cheers
they should fit, yes. sides and front, for that matter.
haha worst luck ever, just got word my trailing arm bushes need replacing. Got quoted $376 for genuine honda supplied and fitted though..
im interested in getting the jdm vtec cluster for the da and just wanted to know if wiring will be an issue? whether it is OBD0 or OBD1 as my car is a 93 model with OBD1 wiring.
thanks
not sure about the vtec version of Jdm cluster but i have a non vtec version and the wires are all fine. plug and play.
really should be fine, but if there is any form of vtec light on the cluster then u might have a problem as there will be no vtec signal wire on ure original harness.
than again that problem is easily fixed.
good luck,
yeh but the wire would prob just b missing on my eg i got the gl so its a carby one and the plugs r the same they just missing the wires
it should fit and not be any hassles
kool thanks guys. so it wont matter what jdm cluster i get and i have to run an extra wire for vtec. at the moment there is no problem as the vtec engine light doesnt show up so shouldnt be any differrence when i get the jdm cluster, just plug and play as you mentioned?
yeh is ur car vtec? if its not u dont need to run the wire it should work with out it all together
yeah ive got vtec. so there would be the wire already running through. i dont get any engine light come on.
I have a 92 JDM Vtec dash, it has climate control but no VTEC light, there is a funky one for the CAT, if its too hot when you stop the car, it indicates this, for some reason they think you will park on top of long dry grass and burn the car :)
I am thinking to use this as the VTEC light, will post a diagram if i get round to it
aw yeh maybe put a sticker over it or something then its looks like just a light instead of the vtec got any pics?
