Quote:
			Installing a line out converter/rca converter
Step 1
Locate the wires running from the head-unit or factory amplifier to the speakers. In some cases you will find these wires behind the head unit, but it may be easier to go directly to the speakers.
Step 2
Once the speaker wires are found, use the wire strippers to remove 1 inch of insulation from each one. Attach the left channel of the L.O.C. to the left speaker, and the right channel to the right speaker.
Step 3
Solder the L.O.C. wires to the speaker wires and seal the connection with heat shrink or electrical tape. Secure the L.O.C. to the vehicle. Plug in some RCA cables to the L.O.C. and run them to the amplifier.
Step 4
Adjust the amplifiers' gain levels to a medium setting. Turn on the stereo and adjust the volume to a comfortable listening level. Use a small screwdriver to adjust the gains on the L.O.C. up until distortion is heard, then turn the gain down until it goes away.
Step 5
Turn the volume up on the head unit and make sure that there is no distortion present in the amplifier. If distortion is heard, adjust the gain on the amplifier and L.O.C. accordingly.
 Do I need to strip the wires from behind the stereo, or can I just go straight to the speakers? I'm planning to connect the converter to the rear speakers...which would be much easier than taking apart the dash
