Originally Posted by
RPS.13
			You'll most likely fine that the stock tie rods are too long to get that amount of negative camber and zero toe. I was unable to zero my front toe at about -1.08.
The max negative camber i can dial in now is only 2.38ish, and that is with adjustable everything. Camber tops, camber bolts, Todd's adjustable tie rods, Akom/McGill motorsports inverted tie rod ends.
The above numbers are at maxium low. But i don't see much difference with the issue of the length of the stock tie rods at stock height.
