Yes, EG/DC2/DC2R springs will ALL fit on DA struts, and vice versa.
EG and DC2 struts fit straight bolt on, you just need the front forks from an EG/DC2.
DC2R struts also bolt straight on but you need the rear control arm to swap, and I presume the front forks as well.
hey guys
would civic (92-95) clear side indicators fit on a da9?http://www.cartoys.com.au/products/H...?SC=9M-HO15L99
Yes. And the DC ones fit too.
many thx buddy.
hey, i know this post was from awhile ago but i was reading through and thought that i could help.
I use to run at QR (until a recent defect) and as i got my times down into the 62sec range i found the brakes were getting hot at the end of the sessions. this caused a long pedal and general brake fade. for the next track day that followed (november last year, before the power upgrade) i had upgraded the brake fluid to dot 5, bought some slotted rotors, removed the heat shieds from behind the front discs and fitted some project mu hc+ pads. this improved the brakes greatly without the need for an expensive refit of front end gear.
just my 2 cents!
I haven't actually done anything to fix the problem yet....... I've been way too busy with uni and I haven't even considered taking any of my rides out towards the hills. I'm planning on some decent pads and fluid plus a general clean up of my brakes. Hopefully that will fix the problem, if it doesn't I'm going to look at slotted rotors.
hey guys
do DA9's have a electronic aerial?..
cheers
yes they do. it's huge aswell.
i thought so...mine just stays up..is that because of the aerial its self? (motor or somethin) or is there a switch somewhere..because i dnt have the stock stereo unit..
cheers
well either its broken, unplugged or has not been hooked up to ur new head unit. if it makes a clunking noise everytime u turn the car on and off. if it does that means its the motor or something. if not and it just stays up it could be unplugged or not hooked up. maybe as a result of the motor being broken or ur headunits lack of control for electronic aerials
