yeah i did, took me 3 hours, 2 hours were trying to get my FINAL nut off! i ended up shredding it up. i suggest using an 8mm spanner and NOT shredding the nuts! right light came off a dream, all 3 on the left came off perfect but then that 1 in the corner behind the car frame gave me HUGE troubles; ended up getting it off with the hugging bit of a 8mm, god i was happy. Used a hole cutting piece for the drill, bulb casings fit PERFECT, held together with high adhesive tape and did all the wiring in about 20 minutes for both, dont tape/shrink the wires in place until you test the light and make sure brake wire is to the cars brake wire and the park is to cars park, left one i had to switch around, took 30 seconds then i just electrical taped it all up firmly, put the rubber casing back on, screwed it back in and there i have ek9 lights for free!
