indeed correct, they do fit, our chassis is an exactly identical to their SI model
You need to do battery relocate to fit the PasswordJDM intake.
Yeah I read about that. In that case will pass. How much would it cost to have someone install a CAI as I don't have the skills to DIY
Installing a cai if real easy, no skill needed and not worth the pay to get someone to install, unless you need to relocate battery. Its a matter of just joining and bolting things together. Usually a 20 min job
Great opportunity to develop skills as a DIYer!
I think installing RBC is more complicated than one would had thought. You either need to cut part of the radiator top support or beat it to make some spaces for the RBC.
If changing the manifold didn't involve permanent change to the car's body then I would probably go with the RRC which supersedes the RBC.
I'm cbfer. I can install a stereo system, adjust coilover height and that's the extent of my skills. Don't you have to take front bumper off for CAI and do other shit. SRI I can install myself :)
i dont even have a jack, or id at least change wheels and shit by myself
I just installed the window lift kit for my car and now the auto window is stuffing up. When I go to close the driver window by flicking it to manual mode, it raises to the top and then will come down about 5-10cms and stop there. When I close it manually, it will work. Any ideas on how reset the windows. I've tried holding t he button down for 5 secs and also up for 5 and still doesn't reset
Just saw Icebox on the avenue roundabout at Granville. I was walking home ahaha
