Yeah I have slightly less than two fingers gap on the front. Your too low tbh. I have no scrub at all on full lock even when I run the BBS with RE55's.
NGK IFR7G-11KS
NGK ZFR6FIX-11
NGK bkr7iex-11
Ive heard of people having issues when isntalling headers and exhaust and getting a CEL. I ran for about 500km without any codes after install, then I went to fix some leaks in the exhaust with some gasket sealer and then got a CEL straight away???
Any ideas if this will go away after the sealer dries?
One O2 sensor is at the end of the headers and the other is on the test pipe.
The leak happened at sandown when I went over the ripple strip and put a small hole in the pipe, so I went to bursons and bought a heat activated wrap/resin that hardens with heat. Before the hole I had no CEL. As soon as I got to fixing the leaks yesterday I got the CEL could be the fumes or I could have hit the sensor. Either way Ill take it for a drive tomorrow and see if they are gone.
That IACV is great haha. Finally had time to clean mine out yesterday and now my surging is fixed:)
Now to run in that clutch!
Spotted white EP3 on mt lindsey highway, epk20, anyone here? lol
Anyone know how much fluid is required for a full brake and clutch flush? Also any recommendations as to what brand is good?
