more points to tune I believe plus other things
You should look into this:
http://www.ozhonda.com/forum/showthr...pore-OCT-12-13
Ah cheers man. I saw that before but wasn't sure I'd be home. Turns out I get back on the Friday. Stupid question, but what'd be the go with using one of the supplied Honda ecus?
Hondata*
You'll need to get your immobilizer reprogrammed at honda if you get a supplied one. If you send in your current one, you don't need to reprogram the immobilizer.
****en wow one of the clutch cylinders just carked it. friction point was low as ****, and then pedal would get stuck on floor. managed to utilise godlike skill to clutchless shift it to my mechanic, around the corner. lucky.
getting new master cylinder got quoted around 220 for everything.
its not as hard, just wind up the rpm a bit more and when you shift just hold it with some very light pressure against the gate and it will slip in as soon as the synchros line up for that split second. hardest part is being quick without being forceful.
tbh i shifted to 2nd and then just puttered along a 70kph road at 40 to the mechanic LMAO didnt wanna risk it i love my gearbox
by the way does anyone know if the clutch and brakes share the same master cyl?
trying to figure out what caused this, it was driving perfectly, clutch was beefy, felt like doing left legged squats every time i drove, the whole time since i owned the car right up until that moment.
dickhead caused me to ram the brakes hard, subsequently downshifted to 2nd and i immediately noticed how different it felt, less push coming back up on the pedal, soon after at the intersection, tried to engage 1st gear and noticed the friction point was at the floor, stalled and then pedal was stuck. such a drastic change leads me to believe something happened when i slammed the brakes. any experts?
The clutch and brake cylinder are two separate parts i believe. Just a rough guess, something must've been bent from the shock when you slammed the brakes. Pressing the brakes does flex the firewall slightly so some of that shock may have been transferred along the tranny?
