I need more camber at the front. Can anyone recommend anything? Thinking of LCAs at the moment but not too sure if I trust them. I've already got adjustable top hats and camber bolts maxed out.
You is mad.
Still scrubbin yeah?
Haven't posted for a while. My fd with k24 is tuned, made 150kw on the dot. Only advanced timing to 38degrees due to using silencer daily. So still has more
Rbc intake
64mm throttle body
Injen intake
50 deg vtc
Buddy club race spec header
Skunk2 exhaust
That's sweet dude.
What's your estimate of the final number once you retune after the last mods? 190ish?
Series is running 17x9 +20 iirc. Not sure on camber degrees. Probably around 4deg.
damn egb.... epic!!! approx how much did the k24 implant cost you? it was done at jdmyard yeah? (i think i remember you saying jdmyard was doing it but i have forgotten)
Aries have you got the ASR adjustable camber plate/top hat ?? does it just replace the honda top hat ?? whats the max Camber you can dial in ?
I'm thinking about more camber before for the Honda Nats as I'm still having trouble getting my immense power down out of the tight corners !! lol
No more scrubbing :)
Guards are all pulled. Running 17x9 +22 with 215/40/17 tyres. Not sure on camber.
Dude why moar camber then?
Cause the front looks bitchy compared to the rear :P needs more FAT!
Quick question that I will ask you all guys in regards to fitament of wheels, considering your discussing it :-P
I'm looking at a pair of 17 x 9 +35 Enkei RPF1, I'm going to roll the fenders, I'm on stock springs/suspension (going aftermarket after 25,000km ~ 35,000km), Would you guys see any perceivable issues in regards to rubbing?
I've seen in the fitament thread that one of the members had that exact setup and said he had no issues, but I'm not sure if he had shaved fenders even. After going between here and 8thcivic, I'm almost at wits end :-P .. especially considering I'm not 100% sure on this.
