Anyome know if storing a car for a long time if i should put it up on jacks and take the wheels off?
I think you'd probably have more success in using a jack to alleviate some of the weight of the car. Otherwise you could end up with rust on the extended part of the shocks.
No issue storing car like that
But you should maximise the inflation of the tyres to make sure they stay firm n fresh
Do I need to do a wheel alignment after installing a new rear swaybar and everytime I adjust it (whiteline)?
Is upgrading from the oem 22mm to the 24mm whiteline RSB even a noticable difference? From my understanding there's two points of adjustment for the whiteline one; theres the normal 24mm, then theres a hard setting which pretty much makes it like a 25mm sway bar?
can you eleborate a bit? Should i jack the car up off the wheels take em off amd leave em in the boot or should i jack the car leave wheels on and pump, or.... Should i leave car on ground inflate to higher than normal and leave it? Car will be stored for at least a year.
Hi guys just wondering, what rpm does ur ep3r cruise at 100km 6th gear?
Yeah im actually pretty curious as well. Apparently the car I'm gonna get has a 5.1 final drive but I'm still reluctant to believe it
