Orange recaros?? =P if they make it
hey guys, has anyone installed an aftermarket headunit in there fd. Ive been at it for like 5 hours now. For some reason my headunit isn't getting power to it. And the speakers arent colour coded. It's driving me insane. Does anyone have any tips? My headunit turns on for abit, then it will turn off again. I have no idea wtf is happening.
fk we shit talk much ahha
maybe get a mow hawk and dye it oj.
?!?!?! really?! i got it running, home made light tester haha, my white wire was power, i got 3 speakers running, but have no clue wat wire is my acc power. I've tried all the different combinations but its not working for me. Only 3 speakers are running atm. Not to sure what to do.
take a pic and show us your wire loom...ill show you what they're meant to be
I think the white wire is constant power so you don't wanna use that one
Try this?
:Radio Harness
+12V DC Constant White
Switchedd Accessory Violet
Ground Black
Power Antenna Gray
Remote Turn On Light Blue
Illumintation Red/Black or Gray
Left Front + Light Green
Left Front - Pink
Right Front + Gray
Right Front - Brown
Left Rear + Yellow
Left Rear - Brown
Right Rear + Blue
Right Rear - Orange
Shouldn't the massive wires be power? Should'nt be too difficult to find which one is live right?
Tim needs an orange lip kit
just sprayed my calipers blue...
got cbf halfway through and rushed it
looks alrite still
thanks xenon that helped heaps.
anyone changed their fd1 front and rear brake discs and brake pads?? any recommendations? coz honda said i need to change my rear brake pads and get the discs machined coz it's out of alignment...
my car has done around 45k with the stock pads. i thought they might be due for a change. asked my mechanic to check em while he was doing a service and said id be able to get at least another 30k out of em. (hybrid driving tho lol) stoked!!
Yeah same here. I'm on 47,000km and my brakes are still 80% but they may have been changed...
^danny I recommend if you want to upgrade your rotors get some aftermarket cross-drilled or slotted ones. Will probably cost less than OEM but look much better.
However if you want to save your money just machine your current ones...should have plenty left on them
Anyone know where to get long anodized lug nuts that aren't rays? They're so expensive
Bored.
get some slotted rotors if you need to change them.
If your after cheap pads go for lucas or bendix pads. If you're want abit more force then have a look at intima brakes or hawks HPS
http://i745.photobucket.com/albums/x...11b12b69a2.jpg
i need coil overs bad!! damm this saving up shit! (baby on the way) lol
PLY44 - Is that an LED strip - how/where did you make it?
what suss u got 3-6? just springs or something?
yeah, pedders springs. there alright but wants some good coils.
nah but i'll take one. the pedders are bit bouncey.
hoqwmuch did the Fog lights cost
06 fd?
thats my one the one without foglights stock.
~$600-650 installed from honda, I installed my one myself for ~$440
i got mine for about $200 and got a friend to install for me without charge. they're aftermarket ones, not from the dealer, but still work and look the same as oem.
actually, i just remembered that we got it fitted, but for some reason there wasnt any power running to them. something about fuses?? (im no auto specialist lol) but i took the car to an auto electrician and they sorted out the correct wiring for $40. so approx $240 in total
out of alignment means warped disc??Quote:
actually you can easily tell if your disc is out of alignment...do you feel some vibration while slightly braking? the only reason i can think of is when our disk is out of alignment or the surface of the disc has grooves in it..thats the time we need to machined or re-face the disc....better buy an aftermarket ones..
i dunno...but it's about $80-$90 bucks to machine it from honda...and $290 for a set of rear brake pads...looking at mugen but they're freaking expensive!!!so i might give that a miss...isn't it if you change brake pads you need to machine the brake discs to ensure that the surface is flat like the new brake pads? that's what i heard...i dunno
As mentioned in few posts back ill be upgrading my HU only. Can anyone advise if a new battery is required to power a 7" touch? Also how long can I use my HU without the engine on? Only while im waiting to pick up someone so it wont be more than 1-1.5 hrs.
nah same battery should be fine im sure. cant help much with the second question but i reckon you'd be fine waiting up to an hr maybe? not too sure though lol. ive waited about 1hr with music on n stuff and it was fine but yeah havent got an aftermarket heaadunit
yea. just worried cos if i run a 7" display, i might be watching a movie. So i dont know how much power it will drain with the engine off
I'd be making sure my battery is 600cca or more...just to be safe. But a stereo usually doesn't draw much current...if you have a powerful sound system I'd be worried otherwise a movie with ample audio shouldn't be a problem. If you're worried start the car for a bit now and then :p
anyone know where i could source a cheap mugen lipkit in QLD?
buddyclub have long nuts. these are only a 16pc set though. not sure if they do 20pc sets.
http://cgi.ebay.com.au/BUDDY-CLUB-BL...98133444561779
or u can get some cheaper D1 nuts, like these
http://cgi.ebay.com.au/D1-1-5-FORGED...item41523c6110
Stock batteries aren't great and if you're still using it I think it's time for a new one
i've just hit 47,000km's and at 43,000km's the dealer mentioned i had only 3k-4k left remaining for rear pads... I can already feel the brakes taking longer to respond.... so time for a change soon when i find a set of aftermarket rear pads.. most probably project u
looks like everyone needs new brake pads haha
p.s. car went in for repairs today, i cant wait to get it back!
im still only on 32,000km... LOL
i got my eyes on these O:
http://sphotos.ak.fbcdn.net/hphotos-..._5321824_n.jpg
mat VIP! I reckon you'llget sick of th em quickly tho
lol stig iv'e done 28000k's. :P
you eyeing the wheels? i want those brakes!
Ive done 7800kmns ^^ My gettings slowly getting sluggish and isnt responding as quick. does anyone else have this same problem and have a solution?
^ after your 1st change oil man...its going to be different
xenonkuraz asked if there were any other long anodized nuts on the market other than rays, and nobody seemed to give him an answer, so they were just my findings for him.
speaking of lug nuts. i havent cheapened out on nuts on mine this time around :p
http://i53.tinypic.com/25s7xx3.jpg
http://i52.tinypic.com/2ex5yjm.jpg
http://i56.tinypic.com/ifd1z6.jpg
looks great man. paint your calipers to match!
there's nothing wrong with cheaper nuts...if they're made from good material there's no reason why they won't last.
just make sure you buy something reputable
and i went for the buddyclubs
but steel made nuts are far better than alloy made ones interms of durability..Quote:
i wouldn't cheap out on nuts, because its the only thing holding your wheels onto the car..
ill pick this steel made kyoie nuts over rays or works nuts...and it cost cheap..
http://www.kyoei-ind.co.jp/sangyo/pr...b-17-20pcs.jpg
so true..sometimes it is even better than branded ones..Quote:
i used to use the d1 nuts.
lost 1 @ a mtn run
lol
lol your story reminds me of when I had my r33 s2...after taking it home from the dealer I was too excited and didn't check anything just drove it like a mad kent everywhere. 2 days later i'm driving home from work and i started hearing this BANG BANG GRR BANG LOL BANG noise coming from the front of the car...pulled over to see the passenger wheel hanging on by 1 nut with 2 missing and 2 about to fall off
but then i always had a feeling foul play might have been involved
conspiracy eh xenon?
LOL!
i just aftermarket nuts before on my DC2R rims on my fd and the wheel actually flew off
I got my 1000k/1month serice, dont they change the engine oil at the first service??
quick question, how much are people gettin there lipkits for? i found a set for 800 painted and delievered. is that a good price?
thats a hella good price yo
sure you didn't read primed?.. lol
lol
good point
thats a pretty good price, if it comes painted already. snap it up!
Does anyone have an aftermarket alarm system on their cars?
I'm planning to install one because I'm getting annoyed at having to double-check that the car is locked every time...and I want the shock sensors.
On another happy note...
I'M DOING A K20A CONVERSION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Still deciding if I'm gonna do the gearbox as well...but I prefer the 5speed.
I'm so happy tonight :D
diy, seeker or modproject?
sourcing my own engine and taking it to modproject
You are a nutcase xenon.
Nah man too much trouble turbo'ing the z2 so I'm gonna go all motor
supercharge the k20a! vtec kicked in yo... at 6psi
Where are you going to get a K20A from? Buy one from japan?
finally, the best looking civic will have some sort of credibility
I think I'll be super broke after this. I'm putting some cosmetic changes on hold indefinitely and gonna sell off my rims too.
I'm gonna be car-less for a while :(
I got a good deal for a jdm k20a through japex
ur a freaking nut mate...
wow, shouldnt mention that at all
keep us updated with the whole process
and i have aftermarket alarm in my car i use cyclops
How are the alarms? i want something which sounds nice too if possible, whilst being a decent security system.
Man xeno, you baller and a half! K20a???? you must be spewwingggggg!! updates please!!
my hero xenon <3
how much is modproject quoting you? i think Kamizake paid 26 or 28g for his full conversion with the other parts and labour etc
Stan I haven't got a quote from modproject yet but they are my garage of choice as of now. I'm currently calling around for quotes and I've had one as cheap as $4500. I don't know how it cost that dude 26-28k. Must have been a gold plated engine man
You can go to ART in heidelberg, ask for Ray.
lol stig go fix all that.
