RPS.13 has a set of WedsSport wheels that he is currently refurbishing for his car! I'm a big fan of some of their recent designs.. particularly the TC105. So sexy...
http://i393.photobucket.com/albums/p...ep3/ep3jon.jpg
^his car looks silver in that picture haha but dayum it looks good, those are the exact wheels i'm getting the weds sport SA70 next week :D just wish the offset was a little lower tho.. do you think if i got camber kits to fix the natural camber in the rear it would help make it sit a little closer to the fender? I'm not looking for hellaflush either lol
btw to those who rolled their guards, does your fender where it meets the plastic bumper look abit weird? cause mine does, like it looks pumped then suddenly flat again.
It probably is silver. It's an Si from USA.
@butterfingers: Adding negative camber using camber bolts will not help with inner clearance issues - in fact, I'm pretty sure it'll make the clearance worse as it angles the hub towards your coilover? You shooould be ok with that offset though as over the weekend, I ran what was effectively a 17x9 +33 with 245/40/17 on the fronts with no issues except on full lock. -_-
It's all goods, eventually got it all sorted out.
anyways, is a rear camber kit necessary? I would like to reduce the amount of unnecessary natural camber at the back, which hopefully will help bring the wheels more vertical to the fender for a more flush look, is that possible? I need an alignment soon anyway, just wondering if I should install a camber kit for the rears first. What do you guys think of the hardrace ones?
Do local tyre shops like Goodyear stock hubcentric rings? I think the EP3 centerbore is 56.1mm?
Just installed my Haltech and again!!!
Man did I forget how my more power it has....
Wicked
