Those things are year dependent not because it's a ZC, same thing happened with the D
And this is why I always tell people to message you with their D-series questions :D
slightly related...anyone know if a EF8 b16 hi flow cat + exhaust system will fit/bolt onto a d16/zc EF7?
Ep3steve. The head won't bolt strait on. D series and B series have different manifold bolt thingys. Dosnt even fit. Sorry to bring bad news. :(
but other than the manifold itself, ie from the cat back, yes it should fit.
But unless it's an aftermarket cat-back then don't bother. OEM one is small.
cheers guys... from the cat back is good enough. I've heard that headers from some integras are interchangeable?
I disagree ben...a decent header for $120 would be the best bang for buck imo
Which does nothing ! (especially on a D series)
A flywheel , does not increase HP. But it increases response and will make your car faster in all aspects. So , putting $300-400 into a light flywheel , is far better investment in a $120 header that does nothing. Id bet the same amount of money on anything else...will not produce the same results or "feel" or "smile factor" to the owner/driver.
