Then you have no need to open your mouth. By the way those times in my signature was with an old almost blown engine running on 7psi and the gearbox at the time only got into 3rd that one run.
owww its tinkerbell with such a gay name
gotta love those B18B's ;)Quote:
Originally Posted by GSI-PSI
the engine was almost blown before i turbocharged it. lmao
well, your 13.8 is to be comended then :thumbsup:
lucky you could swap it all straight over, and that kinda explains why you are such a die-hard B18B supporter... it has worked well for you...
tinkerbell this issuee is sorted
the end of the day the owner chooses which car he wants to turbo
if me and gsi-psi are such b18b supporters what does that make you ???
the only reason your a b18c supporter is cause you have one
noone needs to hear your crap anymore ... go back a few pages and you might see that people find you annoying...
seriously stop the talking
the last thing i will say is that i dont have a B18C...
the guy that started the thread has made a choice now and picking up a integra vti-r on friday and he will be turbocharging it so case closed
I dont think that's the issue, I think you should be able to START threads, but only people with cred should be able to respond to it.Quote:
Originally Posted by ProECU
All well and good in theory, but there are many people on here that have a wealth of knowledge but rarely post, therefore how do they have 'cred'?:)Quote:
Originally Posted by yourfather
A B18b has a lower compression ratio of 9.2:1 which is better suited to boost, you can run 10psi easy on stock internals, without the hassles of variable valve timing you can also run cheaper engine management systems. The case is open and shut, you can run more boost, more easily, more cheaply with a GSi over a VTiR or Type R. This is an argument of economics and cost benefit analysis, you will always be ahead with a GSi as you're starting with a motor that is going to cost you less of an outlay to begin with.
Trust me, I've been down this road, turbo on variable valve timing with after market ECU is a major pain in the arse, you're better off starting with a non-VVT engine. Why would you spend $2-$3k on an ECU to run VVT when you can spend $800 on an ECU that will handle non-VVT just fine? That alone solves the argument.
dat was a strong bump
9 years hehe
