Mounting is no different, they bead the same, they hold the same pressure, they run on the same pressure, they handle no differently.
all you guys are forgetting that tires are made of that flexible stuff called rubber, along with nylon and steel.
If you're anal, the lack of sidewall flex is transferred to the tread that is contacting the ground. Depending on the compound of tire this may cause premature wear, but of course driving on the road doing the speed limit doesn't wear the tire as much as say "spirited" driving.
In terms of roadworthy-ness, you're only allowed to go 15mm taller or shorter in rolling diameter, and the same goes for width, when compared to the factory tire size, found on your placard on the drivers side pillar (assuming its a 90's model honda that hasn't been resprayed) So anyone rolling a 15x8 with a 225/50 is technically "unroadworthy" in victoria anyways.
The angle of a tire's sidewall has nothing to do with the bead of the tire. If you've ever looked at an unmounted tire, the bead surface isnt a square 90 degrees. Also the bead surface on the wheel is usually larger then the bead surface on the tire, and also has a lip that acts as a "fail-safe" of sorts. The reason wheels and tire diameters are made in intervals of inches is due to the fact that they squeeze over the bead lips to create an air tight seal.
Im not going to go into the way that temperatures affects the pressure within the tires, because surely you all arent that stupid.
As far as camber goes, sure it affects the weight distribution on the tire, but that's why they have load ratings, if you're within the limits, it makes it much harder to "roll a tire off a rim". The sidewall doesn't contact the ground until you're getting to the -20's camber specs, believe it or not Super-DA9, even under cornering.
http://farm6.static.flickr.com/5208/...50419547_b.jpg
That's -6.5, that's also a 215/40, At that point in time, you can see there was plenty of tread, and the sidewall is well clear of the contact area. Another misconception is camber = tire wear, when in reality toe is the biggest factor in tire wear.
I know I've just wasted 10 mins of my life typing this in response to forum trolls, I also know that you will still debate and nit pick what I've written and tell me how unsafe it is and how many people I have and will continue to kill.
UMAD Ozhomos?
