Installed my new set of Accel 8mm Thundersport 300 leads.$40 delivered from the states. and my J's Racing Carbon intake duct for the front bar.
Thanks for the info and links guys - will look at some new leads me thinks.
did a FAIL on the weekend, thought I was rad getting a brand new OEM Type R Throttle Cable to do a tucked style under the IM.. but stoopid idiot forgot the US was LHD so the cable is WAY too short :(
brother, if you want to do a throttle cable tuck use a ek one, i did it on the weekend
yeas it will do the job, if you require pics please let me know, dont pay more then 10 bucks for a cable,
I have dc2 vtir one, that's pretty short, will it work for you?
Installed my overnight parts from Japan.. well the rears at least, fronts will go on when I can paint the skirts a fresh coat of black
http://img403.imageshack.us/img403/8907/49422761.jpg
how much for the set of 4 mun if you dont mind me asking? can pm me if you want
oh and where did you get them from?
$110USD for these bro
http://www.ebay.com/itm/New-OEM-Genu...#ht_2570wt_929
CB knows, I bought a mint set off him, good price.
thanks CB.auto, great service
install oem mudflaps to eg hatch
paint stripped plus wire wheel b series rocker cover, waiting for 2 -10an bungs to arrive to be welded on cover for catch can setup.
will be spraying rocker cover metallic bronze!
slowly prep for my next wsid .. :(
removed motor last weeknd
http://img189.imageshack.us/img189/7921/motorok.jpg
Uploaded with ImageShack.us
shave the block for more shaft clearance
http://img208.imageshack.us/img208/5083/blockok.jpg
someone else doing a h2b aye? whats the plans for this build?
http://i.imgur.com/oU6E4.jpg
new headlights...
my plan basically still the same the car will running stock h22 motor but this time with new clutch, lighthen flywheel, cam gear, new seal because too much oil leak, new hasport mount, hondata etc
Where you getting all your h22 seals from? I found it hard getting seals for Jdm h22a when I was putting together my h2b cause most of it is discontinued
what seal you looking for? i think jdm h22 or not or type sh are the same, except the head gasket different
you can buy from ebay and jdmyard also selling em but anyway i bought my vrs kit for h22 from local store it comes with everything
just curious in case my mate needs it, i sold the h2b setup ages ago just wondering because when i wanted vrs kit i couldnt get a hold of one and yonas didnt have any either. so you just got it from a local honda?
i got it from my local spare part shop not from honda
well.. on the weekend anyway..
http://i89.photobucket.com/albums/k2...0420121800.jpg
nice setup what power etc you running?
I havent had it tuned or dynod yet. It's running on a basemap we made. Haha nothing to crazy, but definitely quicker. :P
Good job Onion nice to see it done, tune it and post some dyno's :). Gonna start building my B20 vtec ;) soon
cleaned up my engine bay for abit on my sedan.
and nothing on my hot pink hatch
9" 6uls bronze will be wrapped in 225/50/ tyres
http://img641.imageshack.us/img641/9...0421151451.jpg
Picked up a ITR rocker cover that had paint damage. waiting for some 10 an bungs to be welded for catch can. purchased spray on paint stripper and clean it up, ready to be painted bronze metallic.
http://img193.imageshack.us/img193/2...0421154508.jpg
Purchased hardrace steering rack bushes,
http://img546.imageshack.us/img546/2...0421154757.jpg
Purchased ITR intake manifold, cleaned, hot washed + acid bathed, thanks to dynall and 89 lude for wrinkle black inspiration.
http://img24.imageshack.us/img24/764/20120421154543.jpg
Purchased extended studs for the 6uls to fit over. + purchased 1 wheel nut as i misplaced one years ago.
http://img15.imageshack.us/img15/796...0421154810.jpg
Purchased hardrace roll centre adjusters. front end parts nearing a complete!
http://img842.imageshack.us/img842/5...0421154822.jpg
Purchased Rear trailing arm bushes hardrace.
http://img811.imageshack.us/img811/3...0421154944.jpg
Purchased aftermarket front bar replacement, as i hacked up my old one for track. will be painted in a few weeks along side with spoon mirrors and rocker cover and js racing air duct.
http://img837.imageshack.us/img837/6...0421155123.jpg
Purchased oem eg6 lip for daily, js racing one will be on order shortly for hardcore spec.
http://img855.imageshack.us/img855/5...0421155317.jpg
Asdffghjkk
well did all 4 rotors and pads also did spark plugs with oil and all filters also did the washer bottle and jets and wiper blades car is amazing now lol
Got new front tyres
DIY sprayed my calipers Holden perfect blue
Fitted blue work lug nuts!!http://img.tapatalk.com/31b20403-5ab1-5119.jpg
My mate and I Matt black wrapped my roof, installed DC2R springs , DIY amber indicators for $2.50 lol. And on my mates ek did an oil change, tidied up his front lip and swapped spark plugs. :)
http://i51.photobucket.com/albums/f3...9/IMG_1005.jpg
http://i51.photobucket.com/albums/f3...9/IMG_0987.jpg
http://i51.photobucket.com/albums/f3...IMG_0990-1.jpg
http://i51.photobucket.com/albums/f3...9/IMG_0991.jpg
installed defi rev gauge with shift light and installed the oil pressure and water temp gauge in the A pillar mount and bolt it onto somewhere above the glove box.
personally i dont like it, will see if i can make it not too stand out.
http://i1168.photobucket.com/albums/.../interior1.jpg
http://i1168.photobucket.com/albums/.../interior2.jpg
sorry to say but that interior needs some serious work !..
eww
Nice work, but if track car remove more plastics and shit? :P
Removing carpet and leaving sounddeadening looks bad imo. Respray your shifter plastic back to black.
Whats the point of the guages if there all the way in the passenger view, pretty sure if ur racing and need to check ur gauges it
would be easier in the pillar or on the dash slightly to the middle. Why did u need a 11,000rpm tacho slap bang in the middle of your cluster,
are you revving more than 9,000rpm?. Take it as constructive criticism
http://img515.imageshack.us/img515/9...30001large.jpg
put on for wicked wednesday but was cancelled due to weather forecast!
Color coded my mirrors and side strips, took off my shitty cannon and installed a new sound system.
thanks for the reply. there was a reason i put the gauge in the passenger side, because there is a hole there, and i was thinking for to cover it.
as for the deadening, i work FIFO, havent really got time to get to it, the carpet was stripped when i bought the shell months ago, and it was full of dog hairs, so i decided to take the carpet out, and it was summer, so i didnt wanna work on the sdeadening in that heat, and it was dragging on til now.
will clean it up when i go back home next.
as for the techo, i dont revv til 11000rpm, i wanted a rev gauge because i always ovr revv the engine when the turbo kicks in, and i want to keep my eyes on the road, i wanted that guage for shift light really, and my mate was selling it, so i said y not.
will show picture once i touch up the car a bit more.
http://i874.photobucket.com/albums/a...k/DSC03548.jpg
Finally got around to painting it
Wow beautiful colour!
Its a tuxedo black metallic and isn't as silver in person. There is a lot of white reflection from the booth in most of the pics. Actually looks similar to original colour in the above picture which would be highly disappointing lol
This picture gives a better idea I think. Sorry for the huge pics.
http://i874.photobucket.com/albums/a...k/DSC03546.jpg
big booth man truck booth?
nice job
yes it's a truck booth chief runs the shop :)
http://www.carsales.com.au/private/d...5&sort=default
Thinking of buying this, input?
Decent platform to start with. I'd try bargain them down the price of the clutch though considering it'll need rego soon.
Yeah, Its a truck booth jdmek. I should post the pic from outside the booth. It looks ridiculous with a little car in it lol
Also picked these up. Delivered cheaper than I could pick up a set of std corner lamps locally lol. I really wanted the reflected part orange because I did a blinker delete but these will do. Will be getting orange LED globes because the globes supplied are quite frankly shit lol
http://www.ebay.com.au/itm/270910876...ht_1999wt_1037
PGB do you run the shop???
your boss hire the booth out??
i love big booth
installed a different lip on the eg. mugen style
http://a3.sphotos.ak.fbcdn.net/hphot...31565127_n.jpg
Hahaha cheers for that (guessing the black front bar). *edit wings west.
http://i874.photobucket.com/albums/a...k/DSC03559.jpg
http://i874.photobucket.com/albums/a...k/DSC03557.jpg
Fit up early this morning. Coffee and down the shed to fit the doors up now
that looks not bad.....
what's under the hood?
All the engine bay contains a whole lot of priorities at this point in my life. None of them involve horsepower unforunately lol
Its just a family car dude. If it ever blows up then I'll have a think about it
Looking good, how much lower are your rear's from stock? And are you on lowered springs or on a different setup?
Here's the mirrors and side strips. The mirrors turned out good but the side strips came out shit
http://i945.photobucket.com/albums/a...2/95da4255.jpg
http://i945.photobucket.com/albums/a...2/dab01193.jpg
Looking to H2B swap, and gurus here willing to answer a few FAQ's?
