I might head to supercheapauto and try the meguire quik interior detailer and see how it goes
need help. all of a sudden my power steering stopped working and then realised my digital dash stopped working. I turned the car off and back on and no warning lights light up on the dash as well. I checked my alternator fuse and it's fine.
Did you check all of your other fuses at the same time?
Make sure you check all fuses under the hood as well as under the dash, my digital dash fuse has blown twice before.
I'll check again tomorrow. my dash actually lights up but the digital odometer doesn't work, fuel tank goes to empty and no warning lights flick on when I key in the ignition. weird.
anyone here have the omni power clutch master cylinder? apparently it completely changes the way the clutch pedal position and feel in a way that its alot closer to the firewall and is very stiff?
Anyone know where to get new ep3 fl headlights?
You can get them off an ebay seller in the UK. The eBay seller mentioned that they will fit
"however pre-face EP3's will need modification to the bulb wiring successfully fit the headlights.
The information needed to do the modification has been listed by a help user on the forum below:-
http://www.civictype-r.co.uk/index.php/how-to-guides/46-ep3-how-to-guides/72-fitting-facelift-headlights-to-a-prefacelift-car"
http://www.ebay.com.au/itm/200834520...84.m1423.l2649
If you do decide to buy them, I suggest you contact them directly and purchase it outside of eBay to avoid VAT tax that only people in the UK have to pay. I've been quoted 225 pounds + 80 pounds postage which is about $470 AUD delivered which is a good price.
Please let me know how you go if you decide to get them as I'm potentially interested in future.
They are also projector lights, not HID.
Thanks for the info mate, seems like a lot of work to do the conversion though but I'm considering doing it once my EP arrives or when I'm more mechanically experienced as this would be my first car and mod. Would I need to get a HID kit if I want to go HIDs? The guy mentions HID ballasts but never mention the part number or anything so I assume its in the kit?
I'm not too sure. I'd suggest just installing headlights first and see how it looks at night and if need be then get a hid kit which is easy to install. you may be happy with the projectors
