anybody done a facelift headlight conversion here? just wondering how much should professional rewiring cost?
should be <80
How big would u say the EP3 boot is with the seats up and seats down? Would it be bigger than a Jazz?
seat up, jazz's boot is deeper while length and width are similar. also Jazz's hatch goes lower and easier to load.
anyone here tried fitting a baby seat in the back? just curious...coz i've never been able the find the anchors to hook up the baby seat.
picture slideshow would be VERY appreciated! =)
i have fitted a booster but not a child seat. if you take out the boot mat and the board, you should see a clip at the bottom. you can put the hook there.
extract of the JDM owner's manual, refer to the 2nd and 3rd pic.
Attachment 16753
FYI I've tried transported a 50" LCD TV including the box and packaging last week in the EP3 with the seats folded down.
The guys from HarveyNorman was 110% doubting me it would not fit in the EP3 & tried to con me in getting it delievered for $44. Felt good proving them wrong and shutting them up.
Anybody running one of these?
Kenwood DNX5360NAV http://au.kenwood.com/Car_Entertainm...ems/DNX5360NAV
About to install one in my EP
Just started my clutch job on the ep3
All good..... Except front swaybar endlinks seized so I'm cutting them clean off.
Dc5 shares the same endlinks right ?
You've got the answer NOW! GO Benny so you can come tomorrow night :)
it's not mine! honest! hahahha
oooo.....how much did that cost?
Edit: btw...my rego's coming up and "requires inspection". is it just a normal pink slip? or blue slip? and anyone know ay mechanics who would do the pink slip for me without ripping me off? and does this happen everytime my rego comes up? rego+cracked windscreen = delayed exhaust = flub crying
Pink slip is required for cars 5years or older in NSW. Blueslip is only required if your car is out of registration for more than 3months. E-Safety check should not be more than $40 at any local mechanics.
Flubber knocked up that asian girl hard, hes expecting triplets and will need 3 baby seats on the back of the ep3 lol
Lol grant can't believe you hooked up with her only to knock her up ;).
thanx tony!
lawl...you guys are bastards...hahahaha
I just bought this exact model! I installed it myself after jb hifi telling me it was $280 to get it done. Works great, gps is instant on, but the issue I have is the faceplate around the HU doesn't fit due to the curve of the dash piece, I'll take a pic later and show you, and if you want I can pm you the way to get an oem logo on the startup screen instead of the kenwood o e
Dam flubber ur a player !
Sent from my HTC Desire using Tapatalk
I'm off to WSID tonight if anyway's not scared
ive seen two done so its possible!
Two in the back one strapped on the roof! LOL
bit off topic guys but people from melbourne, anyone dealt with craig from colorurmags in highett?
hes had my rims for over a month and cant get hold of him
any suggestions?
have you confronted him about it personally? could go to consumer fair trading? lodge a case?
clutch is pain in the arse to change fellas - just a heads up ! You need tiny baby hands to access the front bracket , remove a few clips and then remove the lower bolt to the starter motor. Ninja ****ing hands
diy'd the clutch bennyboy? what combo did you end up going with?
First time out with the new car plus stock as a rock..
Felt good but the number is show that
Then again! going from a 1000kg car with 160kw to a 1200kg with only 122kw will take some time to lean how to drive her..
2 x 14.8 2.2 60" 95 MPH every run was the same
I have some just mounted under the rear seat. You must remember that once a car starts to be complied on a regular basis, they dont actually get complied properly like they should and shortcuts are taken. (eg not all the pieces thats meant to be there are there).
I don't.
Stock as....what type of rock? Some rocks are quite fast you know!
Time for some oooomph huh?
Sent from my newly acquired iphone ozhonda forum touchandtalk and not like supersteve's HTC Desire using crappy Tapatalk
just wondering if any of you guys are running aftermarket camber arms? if so what brand? and which is the most durable?
i'm looking at getting either:
skunk2
buddy club
k-sport
megan racing
of the ones listed, which is better? I've searched could find an exact answer, i'm leaning towards skunk2
hi guys, quick question, not completly ep3 related, but im doing an install of a headunit on my ep3 and it has a gps reciever, it needs to sit on the dash, right underthe windscreen, i worked out there is enough space between the door and the car when closed to have it feed up, but because the dash is a little slippery, it doesnt stick with electrical tape, has anyone done something simmilar? any ideas? i was thinking dabs of hot glue gun...
double sided tape?
3M double sided tape?
3m double side tape+alcohol wipe(kfc) + pressure(1mins of it)
Another suggestion is that you can attach it under the dash just above the head unit bracket inside using cable tie and double sided tape. This way it would be hidden away from the top of your dash and your dash would look clear and clean... :)
From past experience, having double sided tape on top of your dash over time exposed to direct sunlight and its UV rays can leave you in a sticky situation when trying to remove the tape adhesive melted on your dash, later down the track.
The GPS receiver is usually quite powerful so you won't have any problems with signal strength if you do choose to tuck it away.
could you put it on that little platform thing under the coinholder/ashtray if the unit is small? would it still pick up signals?
was thinking of getting the gps unit for my alpine or just go and get a portable garmin,slim gps
Racetap works a treat too. Those things stick really well
Hey Steve does your exhaust give you a headache? or any droning noises when you drive?
sent from my iphone.
what headers you lot running ?
After a bit of chit chat and mish mash - the big thing holding back our car is the header + cat/catback apparently , and just the addition of a decent header and cat back helps considerably. Plus I will supercharge the ding in a few months so why not.
kiddracing gets OK reviews. Cheap too. Any comparisons to say the might TODA or similar headers ?
Nope the toda cat back is perfect for me for daily driving also its not that loud to attract attention when driving normally. Its loud when vtec though I find
Spotted a white CW pre-facelift EP3 at Lidcombe Shell this afternoon, left as I just came in to fill up.
Placed a deposit on a 2003 CW EP3 today.. looking forward to joining you all soon! :)
Hey guys. do anyone in Sydney know or have been to a place that install foglights? Thanks in advance yo!
That's crazy man reading the thread up to date, reading through 300 pages was hard enough
hey do any of you guys from melbourne know what the market value for the ep3s are now?
ho much would toda headers and hi flow cat set me back? install and not installed
aslso need new engine mounts.. any recomendations?
btw how much would a fl left projector cost? mines is oxidized like crazy..
