If I were you, I would just go with whichever ECU your tuner is more comfortable/familiar with and whichever one they would recommend.
Hmm seems like haltech seems more local in Brisbane, even the hondata tuners are moving onto haltech now.. Does haltech come with launch control?
This means everything, your tuner should be familiar with your car and you should get whichever ECU your tuner more adept in.
Which Haltech?
If you're referring to the Haltech Platinum Pro Plug-In for EP3/DC5, I believe it does NOT come with the software for launch control. However the Haltech PS1000 & PS2000 do come with Launch Control function but they've heavily loaded with so many other functions unsure if you want to go there.
Cheers mate, car is booked in with mechanic on Thurs for a service and getting him to look at it. The noise is getting pretty bad and is quite concerning, sounds like something is about to break/snap/fall off... I uploaded a video but the noise is worse now...
http://s68.photobucket.com/user/spun...afc18.mp4.html
i couldnt hear anything on the the video....
what year model is your Ep3? 02 or 05?
if 02 then most probably the steering rack issue.. because when i first got my car, the noise was pretty bad..
not sure if the 05 model has that steering rack issue...
or maybe your driving shaft is about to brake? my friend's EP3 driving shaft recently just gave up on him
Could barely hear it in when you take off, but if it sounds anything like this vid: http://www.youtube.com/watch?v=QtAmJNdfsWI
Then im 90% sure your steering rack needs regreasing. I posted this vid ages ago since its the exact sound i was having on my EP3, so i greased the steering rack and it was all quiet. Apparently theres no grease in there from factory.
Yeah it was a crappy video on my phone while I was trying to drive. The noise sounds a bit like that. Is going to the mechanic on Thurs. It is a 2003 EP3 Type R... Also I think my starter motor is also going and the first o2 sensor before the cat has gone also... Goodbye money! I am hoping this noise is just the steering rack that needs re-greasing but I bet it won't be because it is me. LOL
During slow traffic, there is this chattering sound coming from the transmission side. Particularly noticeable when I'm in second gear at very low rpms and I accelerate abit.
Also, does the rear wiper have its own washer motor for it? Or is it all controled by the front windscreen washer motor? Cause when I turn the switch for the rear washer I can hear the front motor whining but nothing no water coming out. The wiper works as usual. .
Got my Hardrace engine mounts finally installed, first start up the vibration was a bit annoying but 2 days in and i'm pretty use to it.
Not bad for daily driving and I can really feel a difference, going from gear 1 to 2 the wheels don't slip as bad when going hard.
The vibration is only noticeable when the car is idled, and the revs seem to drop slower; not sure if thats due to the mounts.
http://s16.postimg.org/kek4ripc5/IMG_3078.jpg
reservoir is full, i meant the washer pump, If there's two motors, one for front and one for rear :S might just do a rear wiper delete lol
Anyway, does anyone know if the Haltech Platinum pro plug & play ecu for the 05-06 DC5 would plug right into the EP3? or do i need to buy a harness?
