Lock out sensor is basically stops you from accidentally shifting into reverse. I think it uses use moving speed to sense it. As for running kpro I'm not sure, but you'll want prb, prd or pre ecu
Thanks for the reply.
Turns out the Ep3 I was looking at a few posts back is running the incorrect Kpro and has a broken lock out sensor. Also found out that the engine doesn't have a receipt from the builder to confirm the engine hasn't been stolen (also found out that dr Honda is a scam artist from BYR). Thsts just the tip of the issues wrong with the car, I'm glad I got that pre purchase inspection done. Car is impossible to engineer without a legit receipt from dr Honda.
dr. honda? wat tha fuk is this shit
Is this the white K24 going for 16K?
I need to find out what type of standard globes the EP3 has in the headlights. Currently the standard lights are like hmm 2 candle power and the high beams are maybe 4. Looking at getting some HIDs, any ideas?
