Best you go get the code scanned and see what it comes up with. Maybe your second o2 sensor is gone too. What o2 sensor did you get?
Does anyones shifter feel like theres alot of play in it? Like the plastic pivot ball joint is worn, just makes shifting feel so notchy... is there a way to replace it? or should i start considering the BC short shifter? I've replaced the shifter bushings with solid ones and also have the mtec stiff shifter springs but it didnt really help.
^^ Lolol I just pretend I didn't mention it >.>
And with the worn shifter ball, as far as I know the only way to fix it is to replace the whole shifter box. Anyone here running a BC (not bbc) short shifter? I hear it causes great stress to the synchros
Can someone confirm that this is the fuel filter part number for EP3? Afaik it's the same one as DC5
16010-S5A-932
