What's a missing link?
Mod to allow the map to handle boost?
Does the Power FC come with an apexi map sensor?
I didnt install my ECU, and ive never really looked at my map sensor properly.
that might be why im leaning out after 10psi? or is this just the D series were talking abot
nah PFC does not come with map sensor, its optional
Ok but if i still have my map sensor plugged in, its possible its activated on my Power FC correct?
Xenocron for the 2.5 bar MAP sensor, & i believe it fits in the stock MAP sensor case aswell...
the PFC uses ur stock map to read boost
Okay so im gunna get a chipped P28 ecu and OBD2-OBD1 conversion harness from XENOCRON. its like $300 without shipping.. what else do i need in regards to my fuel management. Chrome, neptune??? are they the programs that run it?
When you go to order the chipped ecu, because your also getting basemaps, you have to describe the motor setup, also which program to use. I would opt for neptune cause i know a few tuners in australia use it.
For now i would go down to 9psi til you can get a new map sensor. & if the PFC uses the stock MAP, the stock MAP is still seeing boost. unless you can fit something like luke suggested so the MAP doesnt see boost...
