excellent to see "whiteline" taking notice.
Hopefully this leads to an overhaul of the design process and
an overall increase of product quality too :)
Whiteline's response not only makes me happy with their products but also with their business ethics as well. If this is the way they respond then I will happily make my next suspension purchase a Whiteline purchase!
curious asking the people which had the subframe problem what yr model are their civics?
il like to join the two brackets as one long solid brace like the asr or comptech, spread the load out over all the bolt holes more evenly.
http://i106.photobucket.com/albums/m...z1987/zzzz.jpg
i know it is basically the same sort of thing as asr and comptech, but its the best way to go i recon.
That way, for the subframe to crack, both ears will need to snap, taking more force to do so, the way i see it, having it as one solid mount is much better than a single mount per subframe ear.
Also, nice large backing plates to completly prevent plucking the bolts out.
G'day Everyone,
Thanks for the positive feedback. We've had a look at all the information here, and we have some good ideas, but before we go any further we need to have a look at a car to check it out properly.
This is where we ask for your help. If anyone, ideally someone after a new rear swaybar, is able to bring their EK Civic to our Minto, Sydney workshop, we would like to hear from you. In return, we'll supply and fit a new swaybar. Please email support@whiteline.com.au with your car and contact details.
Regards,
Wojtek.
Whiteline Automotive.
Out of curiousity, can this problem happen to the factory rear end, from time to time the rear feels loose and like it "slips" (liek the rear slides over a bit but the wheels are firmly planted) depending on the corner (usually at moderate speeds) :confused: Nothing looks visual, its like the wheel nuts aren't tight enough, but they are, tyre pressure is Ok also.
any news on this ?
My mate tried ordering a EG/DC swaybar , and they said they are being remade too....?????
