if you cut it then it will not hit anymore. When you hit a bump and your wheels scub does it sound like it's rubbing metal or plastic? also look at your tyre is there plastic on the rear tyre or it's straight cutting through your tyre. Once you trim the rear bar it shouldn't rub at the height your at, atm or when you lower it.
