Anyone in Melbourne interested in purchasing a set of Todd's tie rods let me know
Price delivered (USD before conversion) is $323 for 1, $299 for 2, $283 for 3. Not sure if there's a problem buying more than 3 as >1k get taxed
What are the tie rods for? My car is lowered and has stock tie rods for over a year now and everything seems fine
If you want to run more than -2 deg camber on the front without any toe issues then you'll need Todd's tie rods
I was actually much lower in the rears but i recently changed my wheels to +24 and had to raise the rears by about an inch or so... I don't have camber kit in the rear so can't adjust, so will just have to make do for now until i decide to purchase one... the fronts remained the same height with slight scrub on driving on uneven roads.. I have adjustable camber plates on my coilovers on the front so can adjust to my liking, so might play around with it later and maybe change it to around -2 to -3..
what camber settings for front and rear would you guys say is most aggressive without dramatic affect of camber wear on the tyres?
It's toe that kills tyres not camber. Settings depends on the tyres you're using. For street tyres, something like -2f/-1r is sufficient to handle pretty good and not attract the poopo
Just got my wheel alignment fuark it feels much better, rear end less twitchy. camber -0.5f/-1.5r, toe 0f/0.7r
0.7 toe in each side. Josh at TT recommended it, said it would help to balance out the neg camber in the back and make rear end more stable?
All natural camber atm. I'm still waiting to order shortened tie rods and coilovers, and put them in with F+R camber kit at the same time then get it set up properly. +1 for traction tyres :thumbsup:
Yes that is a fair call. The boys down there know what they are doing
Since we're on the wheel alignment subject, here's my wheel alignment results.. Does it look about right? Bear in mind, rear have no camber adjustment
http://img707.imageshack.us/img707/1171/mkk9.jpg
