Nice! What wheels are those? and fitment specs?
Type R hands down. I rkn the red nuts looks nice. Red+silver accent colours e.g honda badge.
If I could re pick my kit, it'd be a type r withs J's lip.
the oem endlinks is fine.. its where the endlink connects to the lower controller arm that is weak.. the metal where the endlink is attached is thin and can break off from the lower controller arm if alot of extra stress is applied.. i had on the cusco 23mm RSB which is thicker and heavier than other RSB
9+32 with 225?
Thanks man! SSR Type F rims. Front wheels on 225/40 and rears are on 215/40 for more clearance
Hahha yeah. I think the RR is a bit too common but yours looks awesome in white! I originally chose the red because of that exact reason but i think it stands out a bit too much for my liking,
Thanks mate!
Wheels are SSR Type F silver 18x9 + 32! front and rear fenders rolled lowered on coilovers!
get smaller size RSB.. i havent heard problems with 16/19mm
if u do get cusco, try not to hit the rear wheels hard onto curbs and such.. other option is get the metal reinforcement plates (e.g Corsports USA) that reinforce the thin metal on the lower controller arm where the endlinks connects onto from the RSB
the oem endlink itself is fine, its got a small rubber 'CV boot' what has fluid in it which makes it flexible to move
so in my case, i hit the rear wheel on the passenger side on a curb when turning left and it was pretty hard.. with that hit, the force on the left rear wheel went across the RSB and broke the metal connected to the endlink off the lower controller arm on the right hand size (driver side)... i noticed it when everytime i turned, i would hear a clunk at the rear wheels and saw that the endlink would be hitting the controller arm... and yes with the endlink not connected, i notice a difference when turning.. understeer
Yeah but because you have a clean black ride. Your wheels are the focal point, the balance between the cleanliness of the body with the semi-loud wheels is good. In my opinion, if you silver dipped the top part of the grill would make the balance perfect.
Soz, graphic design expertise popping up. lol =P
+1 Rep.
Sounds good, no need to look for Aftermarket Endlinks then, Will prob just get the 19mm RSB (Less hassle).
Ill skip the FSB, as I would like a tad more oversteer to balance out the steering of the front & back.
Maybe invest in a Rear top Strut brace (Corsport/ or just a Ultra Racing)
Seriously, what would I do w/o you guys! =)
hi guys asking some dumb questions again, which K&N air filter does honda civic FD sport 2006 used? cant find much info, FD is not Si mode right?
