sand back a bit then paint over.
your shock should be covered under warranty.
17x8 +35 will be too weak. It will look pretty shitty.
Question for you - are your guards rolled? You'll need a flat roll to get some 'flush' fitting rims.
I suggest if you want 'flush' but no hassle with guards and fender work... 17x9 and around 30 offset I reckon is where to be at.. with a 215/45 or 225/45 tyre should be okay with guards rolled flat and a touch of neg camber. Only thing with this is that not many jap rims come in that width and offset... It will mainly be like 17x9 +35 or above.
I personally would rather get the set of rims to be the specs I want, and not run spacers but heaps of ppl here have run spacers and loved it
Awww, spolied the suprise. =P
+1 Rep
I just calculated that offset for 17x9 +30 which equates to +40mm outward. So we have 40mm before were on the fender when not rolled?
and rolling the fenders, is it true we wont be able to clip on our wheel arches anymore? Coz we cant use the clips connecting them to the guard?
Poking with 17x9 +12 front and just tucking in rear with 17x9+22 rolled and a little flared guards
17x9 +30 will probably poke a little depending on tyre choice if you're at stock height. you need the neg camber to neatly get it tuck underneath the guards
and yeah if you roll flat on the fronts you'll have to cut the guard lining up probably. Rears will be fine
And to above^: yeah for sure.. quality over anything.. or you could just wait it out and keep saving for that perfect set of wheels.
I used to work at Ideal Body Repairs in Richmond. Quit now. Going back to tafe
Yeah. If i was going to save up and get the wheel of my choice i would probably get staggered. I want something flush with a little bit of poke.
And I've got HKS HiperMax coilovers going in the car soon. So i have to get that done first
Hey fellas, I'm selling my car as is if you know anyone interested :(
