hm, i'm a little dissapointed with those numbers actually.
I don't know, but i was expecting mid 14's.
I'm still in for the mild tune though :)
The 15.1 was with VSA on, track temp of 33C and humidity 83 %
KPH was 150.88 or 93.75 MPH
If I can control the wheelspin next time with VSA off I can see mid 14's possible if VSA off can make as much difference as many suggest.
Didn't do any research on launching before going either......:eek:
.......bad mistake.................:thumbdwn:
VSA off should make a nice difference. Even when stock, VSA on and off makes a difference in the fast shifts. So the benefits will be better if you turn it off on your Euro.
nice MPH, it's a shame that with the standard gearing you have to change gears just before the 400m line.
I've only been to the strip once but I ran with VSA on and once with it off. With it off the time improved by 0.4 seconds. Sounds like the car should hit a mid 14 pretty easily :thumbsup:
33C / 83% humidity = :O
Only managed the 15.3 with VSA off due to wheelspin. I only dropped my tyre pressure to 30 psi (20psi better?) so next time should see some improvement.
My 3rd run was at a cooler temp. than the first 2 and VSA on was a test to see what the time would be with no wheelspin, I was surprised myself.
But between my lack of experience, VSA on, high track temp and high tyre pressure, I can see mid 14's quite feasable.
Top end acceleration looks impressive on my slips, but my starts are...................:thumbdwn:
Might chuck out the spare too next time, and :eek:my UBD.....
Just saw this from Jtune website.. some owners of extreme kit complaining of harmonics and unbearable difference in noise levels.
The amusing thing is the proposed solution by Jtune. I laughed when I saw this.. :D
Clients who are concerned about experiencing VTEC and are planning to purchase the JTune Extreme kit we recommended to keep driving throttle position to a minimum.http://jtune.com.au/JTune-Noise.pdf
lol...
So much for the professional & legal system. In these circumstances I'd normally say it looks like it was released too fast, but in this case I don't think so.
LOL, why release a letter as a joke like that?
