Is that with the oil cooler installed?
Mine is like 90c for street driving and 100c on the highway without any cooling mods. Oil: 5w40 Synpower.
So would this be the one?
http://www.ebay.com.au/itm/01-05-Hon...-/271206848422
If you scroll down the check the description, you'll see the following -
*Important* Please use the Below information to determine if the part(s) in this listing fit your vehicle.
Do not rely on the eBay 'compatibility' feature.
Brand New Air Fuel Ratio Sensor (Made in Japan)
Denso Part Number: 234-9005 2349005
Bosch Part Number: 13680 13705 13706 15397 15472
OEM Ref Part Number:36531-PRB-A01,36531-PZA-A01,36531-PZA-L01,
36531-PLE-003,
36531-PLE-305,36531-PLM-A11,36531-PPA-305,36531-PPA-A01
Fits to:
2003-2005 HONDA CICIV ALL
2002 HONDA CICIV 1.7L L4
2001 HONDA CICIV ALL
Warranty: 5 Years unlimited miles.
Thats without oil cooler installed. I'm also using that exact oil and weight; oil temp reading at the oil filter sandwich plate. I wanted an oil cooler cause i thought it was abit high as i do alot of highway driving and recently got a JRSC, but that means i'll also have to relocate my sensors for my oil temp and pressure gauge.
I've also got an aftermarket tegiwa radiator which i'm not sure if its cooling any better than the oem, but when the car is off and when I turn it on after about an hour i notice the temps drop pretty fast.
That's pretty cool temps imo.
Both me and my bro's ep3 measure the same temp in the same conditions. Although both have the same type/brand of oil temp sensor.
The K20A has a small heat exchanger located at where the oil filter is mounted and cools the oil using the engine coolant. Therefore upgrading the radiator will help cool the oil indirectly although not any where as effective as a proper oil cooler.
http://i50.photobucket.com/albums/f3.../oilcooler.jpg
Btw, have you sorted out the pressure drop from 28 to 21psi which you posted about sometime in 2012?
Yeah, I noticed last night driving and it was really cool and rainy and my oil temps were around 76 degrees on the highway at 3.7k rpms and even after doing lots hard runs and red line pulls it didn't even go over 80 degrees, usually it'll be around 85+. My coolant was also alot cooler at 60 degrees. Also recently installed an injen cai which sits behind the right the hole on the mugen lip and did the throttle body coolant bypass to reduce the IATs. haha im keen for winter
As for the oil pressure, it now sits around 28-32psi. I think it was my oil pressure sender on its way out since after a month later it started fluctuating like crazy.
60c for water temp is pretty cold haha. Not sure if that' ok or not because as far as I know ideally it should be sitting around 80-90c for operating temp.
Would you have an aftermarket thermostat installed by any chance?
Any of you EP3 boys got a spare flywheel?
Nah oem thermostat, on idle it goes up to 80-85 degrees, it was a really cold and rainy day so that might have cooled the aluminum radiator a lot maybe
Has anyone tried mounting something similar to a STI vlip on ep3 under mugen lip? rather scrape up a cheap abs plastic lip than cracking the fibreglass mugen. dont want to use that tacky garage door seal shit
strong logic in this one
Not with the Mugen but I did it for the Airwalker for the EXACT same reason LOL.
https://fbcdn-sphotos-f-a.akamaihd.n...23817763_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...02785687_o.jpg
