go to some industrial park at night and do some hard braking, should straighten them out
How thick is the collar ? If its say 7mm thick and you remove it you will lower the car 14mm as the ratio is 2 to1. Thats cause the spring is halfway along the arm, for the front the ratio is 1to 1.
got a pic of what they look like?
Different models have different rear perches
I cant get a proper picture because the coilover is in the car but this is a rough idea
http://i194.photobucket.com/albums/z...7418249237.jpg
Personally I'd just take the spinning adjusters off and run like that if you want that low. :)
Here's a tip for keeping rotors unwarped.
When it's raining or wet on the roads, don't sit at a stop with your brake pedal down any heavier or longer than necessary. The hot pads on one side clamping down and the water cooling the rest of the rotor tends to accelerate warping.
^^ good tip!
reps to thy baller.
