Originally Posted by
RPS.13
			Try upgrading your tie rod ends, that should help.
My EP does that too, but it's not really bad. Only time it was really bad was the first time I took it for a spin after installing my engine mounts. When it hit vtec, it steered my into the opposite lane!
I also notice it gets worse as you go up in wheel/tyre width. On my stock wheels, it's pretty normal, 205/45/17. On my 17x9 regamasters it's probably the worst, 215/45/17.
I recently change from a 16x8 185/55/16, to a 16x8.5 205/50/16 and notice it is more twitchy when accelerating through vtec. Again, it's not that bad.
Try changing your front wheels back to stock if you can, see if it goes away. That way you can test and rule out if it's and alignment issue or if something is broken/worn.
Btw, I'm currently running a bit of toe out in the front. Zero toe in the rear. Around -3.0 front, -5.0 rear camber.
