anyone have any idea about the whole airbag recall? i think the 2002-2005 civics are involved in it
100% serious. The DC5/EP3 toes in with bump travel from the factory, and moving the inner end of the tie rods upwards will only make this issue worse. For example, Realtime Racing, that once ran what were probably the most well prepared DC5s in the world, lower the inner end of the tie rod to correct this (probably in combination with a custom outer tie rod end):
http://imageshack.com/a/img683/4615/rtrtierod.jpg
Correcting bump steer is not a one size fits all solution, you need adjustment and it needs to be tailored to your ride height and geometry.
heyyy
need a driver side light bulb for my EP3
went to jax to getit fixed but they didnt have and didnt know what the light bulb part was..
can anyone help me here on the part no.
i'm pretty sure it's the OEM light from factory manufacture
This is correct, after hours of searching and researching, its as simple as this.
Don't fall for the inverted tie rods, steering rack bull shit. All of it is bullshit.
People may advise you otherwise to make a sale, be mindful.
Google the following term - How to tune DC5/EP3 suspension. 1st link has all your answers.
What to use your money on - Good set of Coils + Rear camber kit (depanding on how low you wanna go) + Good Wheel allignment.
OEM should be the 4000 range since they have a yellow tinge in the white light it emits
No sure about PFL but FL use Philips 85122(+) bulbs which are 4300K
Does anyone know the cheapest place to source MTF3 fluid?
I've seen it advertised on a FB page "Sumods" based in VIC. Just awaiting their reply.
Holy crap $90 delivered to NSW
Ah ok cool - which one in particular are you using? Pro 75W85?
I might stick with the cheaper MTF06 as I'm on a budget
