Gruppe m intake is a must imo
You can use the stock Japanese headunit mounting kit, but best of luck finding a fasica plate to make it look all smooth similar to how they have in the USA, ive bought 3 from ebay they all said "yep will fit" i sent them pics and all and still didnt fit right.
Really want a proper fascia so its all smooth and looks like it fits properly, atm it just has this gap :(
I've owned and EP3 for about a year now and i have some issues with bump steer.
At slow speeds, over bumpy roads the cars steers violently to the left and I hear slight knocks.
Also the steering wheel is not centered, (pulls to the right, when i try and center it)
I have had the wheel alignment done twice now and it corrects it for a while, but after a couple of weeks it goes back.
So far i have done the top mounts, sway bar end links and wheel alignment.
Nothing seems to have fixed it for good.
Wondering if it is worth doing the steering rack slider and ball joints? as these can cause issues as well
Or maybe just go somewhere and get a proper alignment?
The car is running stock suspension and aftermarket wheels 17x7.5 +40
Any advice would be much appreciated :)
What do you mean a "proper" alignment? Are you just doing your alignment: at home? Have a look at your tie rod ends and also your drive shafts for any leaks or excessive play in them.
For the record got the wheel alignment done today, all four wheels. The rear toe was out by 3mm and front was out by 1mm.
It feels better, but there is still slight bump steer at slow speeds.
I think you are right though. So far I've replaced the front sway bar drop links and top mounts.
I've had the suspension checked and there is no play in any suspension components.
I suspect it is the steering rack slider due to the play in the steering wheel when the car is stationary.
My Whiteline sway bar and RM01A are vibrating against each other...
Until today... The vibrations stopped.
I look under the car and the driver side as completely disconnected...
If anyone has been in this situation what did you do?
Did you end up selling the bar for another? Go back to stock? Stiffen exhaust hangers?
I want to know what works.
