biee2, exactly same haha. It comes and goes randomly as well. If i dont drive for a while, its gone (for a while) yesterday it was fine. Really nice, no squeek at all. Lets see how i go this morning.
hey, new here lol, i have an 05 euro luxury, originally bought from the same dealer i bought it off, has always been serviced there also. i cant fault it at all to be honest, ive had a civic also and never had one problem with the civic, bar the clutch slipping and needing replacement. love my hondas haha
its comming from the pedal....not from the engine bay. i have tried to lube it myself using silicon spray with the long tube thing and sticking it into the hole with the clutch half pressed down but it normally onli stays quite for lik 2 weeks when i do it...sometimes not even 2 weeks =.=" thinking i need to realli shovel that stick into the hole and give it a good squirt....lmao sounds corny hahaha but yeah atm its been a couple of weeks and its been sweet.....nice smooth clutch is the best feeling....expecialli after putting up with the squeeky one.
I spray only a little bit. After spraying it, you need to pump the clutch pedal many times to distribute the lube. Sometimes I will also spray a 2nd time after pumping the pedal the first time. If you do it properly, it will take care of the problem for a few months. If it still comes back really quickly, then the seals could already have been damaged and you will need to replace the clutch master cylinder.
