Do you guys in Canberra and Brisbane have Caltex Vortex Gold with 98 Ron Octane?
In Victoria I am only seen Caltex Vortex Gold 96 Ron Octane!
As for whether to use BP Ultimate 98, Shell Premium 95, Shell Optimax 98, Mobil Synergy 8000 98, Caltex Vortex 96 (Vic)..... well the thing is your car's ECU is best suited to the type of OCTANE that the car was tuned for.
Since a higher 98 Octane level fuel actually has lower volatility, which means its harder to burn despite having more potential energy, if the car's Ignition Timing is more conservative than the 98 Octane then your car will actually run richer and hence lose efficiency. Not to mention that 98 is more exxy than 95!
I am still deciding which fuel to use but with a lowly 7000rpm redline only (for a honda neway!) and a biggish, torquish 2.4L engine I would probably stick to lower end 95-96 premium for now.
Only thing I know is I would not use Shell Optimax however, it has very high sulphur content, it will affect the metal inside the engine, run dirtier, smells like bad egg, etc.
But if I will tune the crap out of the car with ECU, prob use Mobil 8000 Synergy > Optimax > BP Ultimate as most tuners don't recommend BP Ultimate as its susceptible to knock.. :(
