Yes,i know what anti-lag is,and since you are specifically talking about launching,it does fall under the category of launch controller.They are not 2 different features as such.They both limit the engine to a desired rpm by way of fuel cut for limiter only, &/or ignition cut for also having the ability to build boost via unburned fuel mix going off in the hot exhaust manifold.
If u want to get technical,the gizzmo & such,are not proper anti-lag since they only achieve it via ignition cut.Proper anti-lag,involves seperate modes in the engine managment with completely different fuel & ignition maps reading off sensors such as TPS,MAP,clutch switch,etc to achieve anti-lag at any rpm or engine load.
Im also sure luke doesnt want the repercussions of running anti-lag,which can include reduced turbo life,dropped exhaust valves,severly reduced cat convertor life & more.Having said that,people are still using it on mildly tuned engines & getting away with it to certain extents,but the end results will come.
"launch controllers" also do not work with mild builds,you can do a much better job yourself.
It does sound awesome however & produces some nice flames without the cat in place.
BTW,u make driving & launching a front drive boosted car sound like some sort of black art,it really isnt that hard or different to an NA version,its not until u get to AWD's & large turbos that it gets tricky with boost.
Anyway,back on topic,
The turbo D, squatting for all its worth:p
http://i58.photobucket.com/albums/g2...250608_132.jpg
