The Haltech Interceptor you can't adjust vtec crossover.cost with tuning is approx.$1500.Not sure on the e-manage,does anyone here know?Also cost inc.tuning?
That's true, but with the hondata flash the vtec point is only being changed by 1000rpm anyway and the trade-off is you're using a generic "one map fits all" flash. ALN has the e-manage ultimate and he said his tuner found the optimum Vtec point to be 5500rpm anyway. He gained 12kw atw on top of an already impressive (120kw+) base figure with his combination of I/H/E.
$1500 for the interceptor or e-manage ultimate installed and tuned (both about $800 for the product alone) is a similar price to some popular cat-backs and for a 12-15kw gain in peak power that sounds reasonable to me. If you decide VTEC control and VTC control is important you can always add a V-manage later down the road (controls change over point and cam timing) but with a basic I/H/E the gains mightn't be worth the cost.
With the interceptor and e-manage you're also getting a more accurate tune that makes the most of the particular mods you've made to you're car.
Sure, not everyone will see this the same way, but that's my perspective. It seems the new generation of piggy-back ecu's are a bit under-rated - the ecu is no longer able to "re-learn" so that's another disadvantage out the window.
/rant lol
Lucky I said no to James when he asked if i can be the prototype euro for jtune extreme kit. If i said yes then i will be in the same shoes as Merlin086. I personally think Jtune are too busy with the civic typer and leaving the euro project aside.
By the way which insurance company did you switch to after the extreme kit installation?.
If Jtune had a Euro you'd bet it would be done by now but since James' CTR is there everyday and he gets personal benefit from it you can bet that's why it's already finished.
lol i cant believe the CTR packages are on the way but euro ones still arent :S
Sounds like best option would be haltech interceptor or Emanage ultimate.
Just a noobish question right how you know what settings to be tuned for? would the guy tuning know what to set it at or you tell him your specs?
sounds pretty good thanks aaron.
Would you prefer Haltech interceptor or Emanage Ult reasons being?
which one would be better?
