should I be using something slightly thicker at 100,000km? is 10w40 ok at this point?
10/30 is fine anything IMO!
Theres really no point to go to a higher grade unless your car is burning a lot of oil or if its leaking. You do get better protection but however it will make your engine work harder in the thicker oil. If you do plan to use thicker oil, never go over 10w40. In the castrol recommendation book, i say about 90% of toyotas and hondas ever use 10w40 and the highest viscosity they can will ever go is 15w40. So just stick with the viscosity that your car is use to and 100 000kms is really not that bad.
george likes the thicker oils for great lubrication :D
I use castrol edge 5w30or 10w30
Why not gearbox oil that's better smoooth lube.
TODA catback arrived today! OM NOM NOM :D
^ LOL! Funny guy ^
WTF George................
i dunno, but i think george used too much coconut oil.....
edit: or not enough
I've got 70000ks on my ep and the clutch went ... :( I ordered the exedy sports organic. Hannys quoted me $500 for the install is that about right? I even name dropped Steve and George...maybe that made the price go up ;P
Sent from my Desire HD using Tapatalk
Its not a easy job lol. Harder than B or D series....if you are having a cry I can beat that Pm me
I find it overrated just looking at it.. and I haven't even taken the bubble wrap off yet!
Hey guys wheres the best place to get a timing belt? And if i go to honda reckon its the same one as a dc5r?
same motor so i reckon its the same, get it off like mekong auto spares or ozi auto spares on sackville st possibly cheaper?
Why do you need a timing belt?
The k20 runs on chain, so it don't need changing.
Hey guys, for a full flush, how much MTF would I need?
Dealership is no help whatsoever. The guy asked for my VIN when I asked how much the MTF cost. :/
drive belt is different between DC5 and EP3.
MTF i think you need 2 bottles and should not be more than $20 each.
Weird. Drain and refill is just 2 bottles for me. Done it many times. Each bottle of MTF is 1L. Ep3 Service manual states 1.8L for a drain and refill.
I get my MTF for $15-16 per bottle. If dealer says otherwise just ask them price match it.
Labour only cost $30 from most mechanics.
Next time when you go into a dealer. Don't bother mentioning you have an import. They just give you a hard time, so you can get off their property.
this man knows what he is talking about.
with oil etc, i always tell them i have a DC5R. and its always been 2 bottles of MTF for drain and refill and i have replaced twice. when doing flush, do you drain, then flush with new oil then refill? if that's they case u'll need more than 2 bottles.
Yeah drive belt! lol. Im just getting this squeakish sound coming from that area on cold starts.
The gearbox on my car takes around 1.7-1.8 of oil.
It's a band of some kind :) no need to get into details!
Enkei RPF1 17s in white 17x8+35 for $1165 shipped to your door??!!! why they didn't have this when i had my EP3??????
http://www.ozhonda.com/forum/showthr...lable-in-WHITE!
Lol. If only they had some concavity, I'll buy it.
Like this.
http://www.s2ki.com/s2000/gallery/pa...933__file__med
who cares. it's an awesome wheel. cheap, light, strong and in the god damn correct colour!!!
u won't get concave in 8" on any wheels.
edit: pete, those on the S2K are still flat!!!
dam they are a very nice looking rim. Would look pretty awesome on a ep3
Pete, Sell the stock wheels and re use the tyres lol
What's a good brand of clutch for the ep3???
Thanks nepo
brake fluid 2 bottles
Thanks!
Hey guys,
The CEL came on yesterday and I thought it was just the oxygen sensor...did the little paperclip pin thing and It came back with code 23 which is the Knock Sensor Circuit Malfunction. Reset the ECU thinking it was just a one off thing...it came back on today. How can I check this problem? I can't take it to my mechanic due to the public holiday. Any advice?
you got a open circuit on the knock sensor. check the pins to the knock sensor. remove the plug, check the connectors, spray a contact cleaner n replug in and reset. make sure connection is secure. Reset cel. if cel comes on again, chg the knock sensor.
noticeably dank smell from in or around fuel pump cover. Should there be any vented scent at all ? possible failing fuel pump or ?
Lol, just realized I had my undies inside out! :S
ive actually gone thru entire working days and found out my shorts or shirt on inside out. Not to mention wearing a sock on the wrong foot !
Lol I've accidentally wore mismatched shoes to work before. Drove home before anyone noticed and save myself the embarrassment
*Facepalm*.
i've had my pants rip where the butt is. thankfully nobody saw and i quickly wrapped a jumper round my waist and went to buy a new pair of jeans.
Some pics to wet your appetite's:
http://i613.photobucket.com/albums/t...g?t=1304409778
http://i613.photobucket.com/albums/t...g?t=1304409779
Guys need a bit of help with my rear coilovers...?
I'm at a bit of a loss and cannot figure out why the left side is higher than the right... The left side I maxed out today, and it has a 1.5-2 finger gap between the guard and tyre. The right side still has about 25mm of thread to wind down, however this side has less than 1 finger gap. Coilovers: BC BR's base height adjustable.
Apart from adjusting the coilover height, am I missing something??? I checked, it doesn't look like anything is bent, not signs of rear end damage under the car...
Forget my post in your other thread.....check/adjust the preload spring height then just check how far out you are in the seat?.
Cheers thanks Nepolian! yeah I left the preload as set from the box... I'll recheck them when I rip them out next time.
Okay cool, i'll check them on the car. If that doesn't yield any result, then I'll flip them. Yeah the BC BR site says, their preload is set 5mm up from when the spring seat touches the spring.
Haha, do it... you know you want too! You don't need balls, more like half a brain... :p lol
Damn RPS, what offset and width is that?
Must be rubbing galore??
hey guys, my central locking is stuffed, all doors including the boot. im looking at some actuators on ebay but wondering if any of you guys had this replaced and still have the part number for actuators that fit our ep3?
Cheers
ive only had it changed for the doors not the boot, isnt it any aftermarket actuator will fit for the doors? not too sure about the boot though.
also what do you guys think of 17x8 +35 all round on stock height? no intentions of coils or anything lower than stock springs/sussy cause im scratching my exhaust over some speedhumps....
My aftermarket actuator didnt go in the same place as the oem ones. The guy had to drill holes into the door to put the new motors up.
just changed to k&n drop in
IMAGINARY +KW FTW
http://farm6.static.flickr.com/5147/...347c396d18.jpg
This is what 17x7 +25 looks like lowered on BuddyClub N+ coilovers with negative camber dialled in. So 17x8 will look pretty much the same from the outside. There is no rubbing and scrubbing (though my rear guard has been rolled). Your RM01A must hang lower than the stock exhaust by quite a bit..
Spookz is that your car? Did u get spacers for your stock wheels?
Yeap, they're 20mm Project Kics bolt on spacers with the correct hub centric rings.
Closest pic I have of a 17x8 set up, +37... but this one is again lowered, no tyre specs unfortunately. Sits pretty nice though...
http://i613.photobucket.com/albums/t...g?t=1304550601
My wheels before I lowered it, 16x8 +38, 205/55/16... not rolled yet in the pic. No rubbing, even though the tyre is slightly taller.
http://i613.photobucket.com/albums/t...g?t=1304550568
The 17x8 +35 will sit 3mm further out... You should get away with a 215/45/17... try use your old tyres first, if your using a 215/45, should it rub then maybe drop to a 205/45, or roll your guards.
Just a pic of my car, Attachment 18579
Hey i think i know this black ep. He use to come into my shop all the time. If i can remember it was a personal import from uk.
just to confirm...EP3 brake pads are the same as AP1/2 & DC5R pads right?
I took the photo at my bosses yard, I just bought it two weeks ago off my mate.
Hey guys, I'm just about to order some discs and pads. RDA STD and slotted. Let me know of your interested!
