Which Type R is it?
The latest one or is it silver with Red R in the middle
Alpine SWR-12D4 <- Latest one / 1,000 watt RMS
Alpine SWR-1242D <- Old one / 500 Watt RMS (If i remember correctly)
Alpine SWR-1243D
- 12" subwoofer with dual 4-ohm voice coils
- Kevlar reinforced pulp cone with Santoprene rubber surround
- Cast aluminum frame with perimeter venting
- Frequency response: 23-500 Hz
- Power handling: 300-600 watts RMS (300 watts per coil)
- Peak power: 1,800 watts
- Sensitivity: 85 dB
- Top-mount depth: 6-3/8"
- Sealed box volume: 0.65-1.25 cu. ft.
- Ported box volume: 1.0-2.0 cu. ft.
Alpine SWR-1243D ?
Is it a slim sub or something?
Stock head unit aswell?
I would get something from the Alpine 'X Power' Range.
Only because it has a low level converter built in. So you can run the amp even with the stock head unit
Unless you dont mind other brands
But ideally you just need an Amp that has enough Watt RMS to match the sub.
Which in your case is 600 Watt RMS
WHO OWNS THIS CIVIC?!
http://www.the-lowdown.com/media/eve...p/IMG_7842.jpg
Planning to get double din
Yeah ill research more as I'm trying to save
That's dixcels fd civic
Get the ECLIPSE AVN827GA.
I should've gotten that instead of my Alpine :(
http://www.eclipse-web.com/au/produc...ion/avn/827ga/
btw what sort of strut bar are u guys using on civic fd? and how much does it cost? is it useful btw?
Strut bar is nuthin more than bling, our strut tower is alot closer to the firewall than many other models. Save ya cash.
Cusco front strut bar
http://www.jdmconcept.com.au/part/cu...fd1-1.8l-06-11
is the ultra racing good brand?
