Injen CAI, does that cause CEL? Or is that more of an American civic thing. and where to get a flashpro for R18a engines? Do they even exist? haha
You'll only get a CEL light if you try and start the car whilst you're installing it, I know because I saw someone do it ;-), twas a very irresponsible move on their behalf.
But you're best to remove both the positive and negative terminals to ensure the ECU resets itself, so when you do start up the first time its starting fresh :-).
Okay, getting the Injen and Hydroshield.
Now the issue about my stock exhaust not fitting the mugen RR kit... I can't just, get the mechanic to just shift it over? It doesnt work like that does it?
http://www.ebay.com.au/itm/IN-STOCK-...item4618008acf
This should fit right? Same model number as the one on JDMyard website.
EDIT: Also, the one on JDMyard/ebay are dry filters right? Did some research and getting mixed results ahaha.
The shield is more for keeping it clean, won't do shit if the pod is submerged in water. Just be careful and you'll be right, bit of water here an there ain't nothing.
Since we're on the subject of intakes...
my warranty is gonna run out may this year, I've been eyeing on this for awhile. It's abit overkill but lets just say I would like the noise.
http://passwordjdm.com/PasswordJDM-D...P3082C349.aspx
